Question about American DJ Supply American Dj Galaxian 3d
Galaxian 3D reset
How do i reset the galaxian 3d to factory specs. specifically sound active?
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Feb 08, 2015 | Kurzweil SP3X 88-Key Stage Piano
I need to fix a 10 k potentiometer on expression pedal on model yamaha EL100. model number of potentiometrr not known. pl advice which one can fit.
Generically, for this kind of part, search Google images for one that looks the same, check the dia of the thread, usually 6mm (4mm is common) and then all you have to find out is weather the part is linear or log,
If the pedal passes audio it will be log. If it changes a control voltage then it could be either. Measure from end to end and then measure from one end to the wiper. If it is half (roughly) the value halfway round then the pot is linear. if not then it is log.
Try CPC, yes this a very long address!!!
http://cpc.farnell.com/jsp/search/browse.jsp?N=411+207396+110135389&No=0&getResults=true&appliedparametrics=true&locale=en_CC&divisionLocale=en_CC&catalogId=&skipManufacturer=false&skipParametricAttributeId=&prevNValues=411+207396&mm=1002553'',&filtersHidden=false&appliedHidden=false&autoApply=false&originalQueryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN%3D411%2B207396%26No%3D0%26getResults%3Dtrue%26appliedparametrics%3Dtrue%26locale%3Den_CC%26divisionLocale%3Den_CC%26catalogId%3D%26skipManufacturer%3Dfalse%26skipParametricAttributeId%3D%26prevNValues%3D411%2B207396
All the best Chris.
Oct 24, 2014 | Music
Where can I find printable writing paper?
perhaps if you purchase a 3D printer, you will be able to find a file for the writing paper you wish to print.
May 29, 2014 | Music
Power comes on, but the lights dont
I can ONLY give you suggestion.... Note that most of the high power laser devices have safety interlocks to insure the beam is moving before turning laser on. Verify any dip switch settings to make sure they are in a suitable mode. If the laser comes on during test, ASSUME that a setting is wrong. I do not have this unit so my suggestion is general based on experience with other devices.
Nov 30, 2012 | American DJ Supply Galaxian Royale LED...
10w 22rj wire wound resistor
When thosse resistors (precharrging of main input filters) burn up there is major damage. The IGBT's are usually gone... replace with APT28GA60BD15... the switching regulator IR2153 is gone... one or more of the 2SA1020-Y and the 2SC2655-Y gate drivers are gone. One or both of the DL4148 speedup diodes for the IGBT gate drives will be gone. The Wirewound ceramic resistors either 10 or 22 ohm 10 watt radials... Use:
http://www.mouser.com/ProductDetail/Ohmite/TWW10J20RE/?qs=GcOFt9%2fAxQHny%252b35G6iehQ%3d%3d
This is 20 ohms, however Behringer uses from 10 to 22 ohms in these units... 20 works fine as does 10 ohms. If you have toruble getting schematic let me know.
Aug 22, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Has anybody ever replaced an entire crossover assembly (circuit board) in a Alesis Monitor One? Specifically, does the woofer need to come out, and if so, how?
Look here:
http://www.instrumentalparts.com/crossover-pcb-board-for-alesis-monitor-one--mk-1-and-m.html
and here: http://ep.yimg.com/ca/I/yhst-15436568105612_2091_46855693
See that 8.2 mfd bi-polar and one of those white ceramic cased resistors???. Those parts feed your tweeter... One of them is bad. You can buy the board for $30 or spend a couple bucks for those parts.
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V47-RC/?qs=sGAEpiMZZMtZ1n0r9vR22WuTsnx9Abs03070dCRY8QE%3d
http://www.mouser.com/ProductDetail/Xicon/140-NPAL100V33-RC/?qs=sGAEpiMZZMtZ1n0r9vR22UhSjrTM10DE0iKGiddcDi0%3d
Put one each of the above two capacitors in parallel to make 8 mfd to replace the 8.2 mfd and it will work fine. They only cost 74 cents each. You can find the resistors as well from Mouser.com.
IF YOUR crossover is potted in a hard material, that probablly destroyed the caps. The caps would have to be encased in a foam before hard potting as the shrinkage of the potting material would crush the caps a bit and cause failure.
Feb 02, 2010 | Music
One string broken, how to refit it?
Sorry Dude
If you can not replace a broken string, then you need a few lessons from a friend.Find a pal to jam with.
It sounds like you broke your E string. Take it down to the local music shop. Buy a new string and ask the guy to put it on for you. Offer them a tip, its worth it.I could tell you. But you need the string so ask for assistance and see it in 3D. Keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
American DJ Supply American Dj Galaxian 3d Logo
62 people viewed this question
Top American DJ Music Experts
Vito Vacirca Jr.
Are you an American DJ Music Expert? Answer questions, earn points and help others
