Question about Makita AF503 2'' 18 - Gauge Brad Nailer
Af503 will not shoot nails, is not jammed & is clean/lubed
Cycles but won't shoot a nail
Need to know the make & model in order to help you!
A couple things to look at:
Check the nail carrier & magazine - make sure there is not a jammed nail or something stopping the nails from moving all the way forward.
Also, check to see if you have a broken driver blade.
Mar 12, 2015 | Tools & Hardware - Others
How do i fix my nailer from jamming
Parts are piston driver replace the point has a problem replace driver AND important use the right nails i think the nails are the nails are not big enough 40% chance this is the problem but when you have shoot on a hard surface the point of the driver will get 2 nails at a time and control part 52 that its not dirty or kinked. and the transport is clean.
Oct 21, 2014 | Air Tools & Compressors
Dewalt framing nail gun want shoot nail
Which model is it? What happens when you try and shoot it? Is it leaking air and if so from where? Is there a nail jammed in the tool?
Aug 19, 2012 | Dewalt Tools & Hardware - Others
Air is continually running but no presssure is building up so the drive pin never resets in order to shoot the nail
Remove head and check seal between headvalve and cylinder. If seal looks good, just remove head parts and clean/lube. Also clean/lube orings between cylinder and body of gun.
Sep 23, 2010 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Will work fine for one or two nails and then nails jam in the gun or it shoots two or three at once.
This is iffy... but PC nailers are nit picky. If you used someone elses nails, it can (and will) jam and mess up.
So, if Porter Cable nails are being used, clean and lube the nail shoot (with a few drops of air tool oil).
If that does not work, Invest 19 dollars in a new, 18 guage nailer at Harbor Freight. I have 2 of those and they have been trouble free for 3 years.
Nov 15, 2009 | Porter Cable 1" 18 Gauge Brad Nails...
Will not shoot a nail,no matter how hard you press the tip of the nailer.
hi you may have a nail jammed in carousel.. unplug and dismantel and locate jammed nail. this happended to me once so this may be your problem
Oct 14, 2009 | Stanley MCN-150 Bostitch Strapshot Metal...
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Makita AF503 2'' 18 - Gauge Brad Nailer Logo
56 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
