Question about Whirlpool SB160PEE Gas Single Oven
Oven takes long time to preheat
Whirlpool model SB160PEE gas wall oven, takes about an hour to preheat. i can hear the gas cycle on and off every few seconds.
    New Friend:
  • 3 Answers
If the oven has a glow bar it,s not staying hot enough to keep the main burner on change the glow bar
Posted on Dec 14, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Posted on Nov 21, 2007
SOURCE: Whirlpool Wall Oven not working
It is likely the Thermal Cut-Off (TCO) fuse, which for many Whirlpool ovens is located on the back of the unit. Turn the circuit breaker for the oven OFF first. You'll need to remove the trim on the left and right side of the oven (2 screws) and then remove the screws holding the oven in the wall. You can locate it easy enough by looking for the thermal fuse on any of the major appliance part websites. The test is simple enough if you have an Ohm meter, as it will be an open circuit if it is blown. There is only one fuse (normally) so if it is blown neither the bake or broil element will work. There should be a Tech Sheet located behind the control panel which will help, but if you don't feel comfortable doing this call a service tech.
Posted on Oct 28, 2008
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Oven takes forever to preheat
check to see if both broil and bake elements/gas works
May 25, 2010 | Maytag CWG3100A Gas Single Oven
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Dec 10, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Loc error message
I unplugged the appliance for an hour and after re-plugging, the problem went away.
Nov 05, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven preheats then cuts off 70 % of the time
have you checked that your timer is set correctly
Jun 14, 2008 | Ovens
Whirlpool SB160PEE Gas Single Oven Logo
222 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
