Question about Plumbing
Where do i find a replacement bladder for expansion tank
  • 32 Answers
Just buy a new tank, by the time you find the bladder(if it is a replaceable one) then struggle to put it in (only to find that you nicked it), you will have more time and money in it than it is worth.
Posted on Apr 02, 2014
Draining outlet
If you have an expansion tank mounted near the water heater, it may be full. If it is full, the bladder inside the has ruptured and the tank needs replacing.
Jan 07, 2014 | General Electric GE GeoSpring Hybrid Water...
I have a 125 gallon tank if I'm correct this bladder has to be installed from the bottom of the tank!
The bladder is not a serviceable part when it goes bad that's it. I have see some of this brand go bad over the years but it is very few and far between.
Feb 08, 2011 | Amtrol ST-80V-C THERM-X-TROL ASME...
Brief Motor boat sound transmits thru the house when kitchen,bath,or shower first turned on.How do I trouble shoot the thermal expansion tank Amtrol ST 5.
The easiest way I know of is to remove cap from air valve on top of tank and check pressure with tire gauge.If you get water out of valve then air bladder is bad and tank will need to be replaced. If you don't get water but no pressure then reinflate to 3-5 PSI. Hope this helps. Thanks
Nov 11, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I am loosing water pressure in my shower so I checked pressure at my ST-12 Therm-X-Trol tank hoping it would be 40 but water comes out of the test point and if you tap the tank it feels like it is full of...
you are correct....the rubber bladder inside the tank has leaked by and filled the expansion tank. it will need to be replaced and you also may find boiler or water heater relief valves may blow off until its replaced
Oct 21, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My pressure relief valve opens, why? I have an American Std boiler Mod# GPMX8. My pressure valve was leaking and boiler was operating at 16psi. After replacing the pressure valve. I refilled boiler and was...
if you have a captive air expansion tank its most likely bad and leaking inside. means the rubber bladder leaked internally. cheap money and easy to replace. do not even try to test the air pressure in an old one. or try to refill it. replace it. good luck
Jul 02, 2017 | American Standard 2770.018w.020 Cadet...
The pump goes on and off repeatedly
The pump should only run if you are using water. If you have a leak it will cycle on and off. If it only cycling fast when you're using water, you may need an expansion tank, sometimes referred to as a bladder tank for newer style. If you have a "bladder" tank , the bladder may be leaking and lost it's air charge. This bladder will have an initial air charge, and when the pump runs it will compress the bladder even further. When the pump shuts off the bladder is compressed. When you begin to use water, mainly low flow like one faucet, the bladder will begin to expand expelling the water from the tank until the pressure drops below that of the pump pressure switch. This makes the pump start and stop fewer times.
Jul 05, 2010 | Flotec Corrosion Resistant Shallow Well...
Water leaking in basement because there is a small leak in current expansion tank. can we stop water from leaking tonight and still have water to house? and are these tanks easy to replace?
For tonight I would set a bucket under it to cathc the water from the leak. The tank will not start to leak much worse in the next few hours...
And, no it is not hard to change the tank. Just messy....:-) Becareful though as the tank may be heavy if the bladder has ruptured...
Simply use two wrenches and unscrew the tank and then tape or dope the threads and screw the new tank back on...just that simple...make sure you get a fresh water exspansion tank and not a heating one...
heatman101
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Hydronic Boiler relief valve problem?
Check the pressure guage. Typically the pressure in a water boiler should not be more than 20 psi. If you are approaching 30, the relief valve is doing it's job. I would replace or adjust the automatic water feed if the pressure is high. Always replace the boiler relief valve. Tap on the expansion tank, it should sound hollow. Replace it if it is full of water. If you have one of the old expansion tank that has no bladder in it, drain it.
Dec 03, 2007 | Heating & Cooling
Plumbing Logo
111 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
