Question about U-Line Icemaker
Have Uline U-CLRC02175S-41 undercounter icemaker. Making ice, but very slow. I think condenser fan motor is bad, but how do I confirm?
5 Suggested Answers
  • 286 Answers
SOURCE: uline ice maker clr2060- makes ice continuously,
This is a problem when the thermistor in your icebin is not being satisfied.Now there is a break in the serial number to find out if you have a thermistor or a mechanical thermostat. If the serial number is before 03 (first 2 digits is the year)and the 2 digits between the dashes is 11(the month) the replace the bin thermostat. If newer then you need to replace board and thermistors.
Posted on May 13, 2009
  • 286 Answers
SOURCE: uline icemaker compressor runs very hot - slow ice production
if the ice production is slow first try to set it on a warmer temperature. Now if its frosted up then you will need to defrost it. Also check the fan to see if its running. if yes is the condensor clean? If yes then check temperature in bucket. 10 to 15 degrees is ideal for this model.
Posted on Jul 07, 2009
  • 286 Answers
SOURCE: Our Uline icemaker is not making ice anymore after
You might of turn it off in mid cycle. You can check the icemaker ejector blade (fingers that push ice out) If thats not at 12 oclock you will have to manually advance it so it will be at 12 oclock position. Remove cover off icemaker. Just pull it off you might need to pry it on the corners to help it along. Becareful that you dont break the cover. When you have it removed you will see 2 gears. the smaller one should have a 5/16 head on it. Turn that counterclockwise to advance the ejectorblade back to 12 oclock. Once you have it in that position turn your unit back on and see what happens.
Posted on Aug 11, 2009
beno8035
  • 4 Answers
SOURCE: uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Posted on Sep 07, 2012
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Sep 07, 2012 | U-Line Icemaker
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Water still runs into ice bin after trays are full on our uline ice maker
This happens when the motor is running slow or the water switch is sticking. To take care of both things you need to replace the faceplate on the icemaker.
Sep 14, 2009 | U-Line Icemaker
Undercounter Sub-Zero leaks onto floor
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 14, 2009 | Refrigerators
Uline icemaker compressor runs very hot - slow ice production
Jul 04, 2009 | U-Line Icemaker
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
U-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
May 24, 2008 | U-Line Icemaker
U-Line Icemaker Logo
42 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
