Question about Whirlpool Refrigerators
How to uncrimp a crimped copper pipe line
Can't get water through my accidentally crimped copper line
tborn6
  • 700 Answers
SOURCE: Leaking oil from crimped copper line
first off there's probably no refrigerant in the unit. the amount of oil is probably minuscule to what the system has.
Posted on Dec 20, 2008
  • 68 Answers
SOURCE: powerstar bosch tankless water heater ae3.4
Yes the device is faulty. the unit should not heat water unless a tap is turned on. Call in a service rep to assess the problem. Do it quickly your description doesn't sound good.
Please rate this response and Good Luck Phil
Posted on Jan 02, 2009
  • 1779 Answers
SOURCE: rear brake line that runs from caliper to frame needs replaced
You can purchase different size (diameter) and length brake lines at an auto parts store. They are inexpensive. The lines are already 'flared' to be connected to another line, all you have to do is disconnect the old line, and attach the new one. Spray the connections several times a day for a couple of days to make them easier to separate. you will also need to bleed air out of the replaced section for the brakes to work properly.
Posted on Apr 16, 2009
  • 19 Answers
SOURCE: hole in copper water supply pipe
solution#2 is one way to do it however those clamps will leak after awhile. You can cut pipe on center of hole and (A) push pipe up and install a copper coupling which does involve soldiering. Or (B) you can get a brass coupling fitting called (Shark Bite Fittings) which simply slides over pipe and locks and seals on pipes. This is a fairly new product and godsend to plumbers and plumbing repair. Whenever fixing pipes in walls check for any form of leaks thoroughly before covering up wall.
Posted on Jul 07, 2009
roger_bri797
  • 23 Answers
SOURCE: marine refrigerator needs recharge w 134.
First find the LEAK.....freon does not wear out or just go away...it MUST LEAK out somewhere...yes you must cut behind the crimp, it will not uncrimp...thanks
Posted on Oct 05, 2009
How can I repair water leak?
Good grief, what kind of water leak? In your car radiator? In the house from a copper pipe? Or a toilet, a sink, a faucet? All these leaks require different fixes. Let us know where the leak is from. Then we'll have a better chance of giving you the correct advice.
I will tell you this, if the leak is from a "pin hole" in a copper pipe in your house you need to get a water testing kit to see if you have acidic water eating away your copper pipes. If so you need to replace the copper pipe and then get an acid neutralizer ASAP. If you do not get an acid neutralizer all of your copper pipes will be leaking since the acidic water has been eating away at all your pipes.
Jan 11, 2016 | 2004 Saab 9-3
Brakes on 93 lincoln towncar seize up after driving 20 minutes.Had new front calipers,new brake line hoses and new
Do you know which one is holding on? I would if it has flexible hoses crimp off the rears with proper brake line crimps & drive but carfully as your brake function will be reduced. If it dosn't happen you know the problem lies in the rear if not you know its in the front. If in front uncrimp the rears & crimp 1 front drive & see what happens but with only 1 crimped the car will want to pull sideways under brakes if problem remains you know it is the other side, repeat with other side to make sure. This should let you know where the fault is if the fault remains its probably not any of the callipers or drums.
Jun 27, 2012 | Cars & Trucks
Can a 4" or 6" copper water line leak be froze
Cut pipe in half at leak and put a rubber repair coupling on.
Jan 25, 2011 | Plumbing
The water filter stopped giving water even though filter is only 1 month old. Tried a new filter, still no water flow
Try removing the water line off of the valve at the water source then turn the valve on and see if water comes out if it does then the line is plugged, look for a crimp in the line if it's copper. If you find a crimp get a coupling with Ferrell's and cut the crimp out of the line and install the coupling now try to turn water on and see if you get water if you do your set if not get back to me for the next test.
Sep 09, 2010 | KitchenAid Refrigerators
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Marine refrigerator needs recharge w 134. how can I install a schraeder valve in crimped suction line? If I desolder line and install valve will crimp uncrimp with sideways squeeze? Or do I have to cut...
This is not a DIY job, You have to call in a refrigeration service man to do this job. Although you may know a little bit about refrigeration soldering and a bit more. Do you have a vaccumn pump to vaccumn the system to 500micro or lower before you recharge the freon. If you do then I don't think you would ask for any question at all.
Jul 06, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Water dispenser problem
Did the man who installed it use plastic hose or copper pie? PLastic pipe can get crimpled (closed) and starve the water supply.
Simply move the refrigerator far enough away from the wall and see if the tubing is crimped. If it is copper and it is crimped- you should call the installer back to repair the copper pie. Once copper pipe is crimped- it is unusable and must be refitted with a coupling or union or some other proper repair.
Maybe this is all that is wrong.......
Hope this helpes!!!
May 30, 2009 | Whirlpool ED2FHEXN Side by Side...
Rear brake line that runs from caliper to frame needs replaced
Apr 16, 2009 | 1992 Subaru Legacy
Think I have pinhole leak in 1/2'' copper water pipe
What type of pipe are you looking at?If it is copper then you can fine someone to solder it.If it is plastic pipe with glue joints,then you get some glue call rain and shine,clean first then apply wait a few minutes.But turn the water first.
Mar 14, 2009 | Plumbing
Routing waterline to pad
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Dec 10, 2008 | Aprilaire 550 Humidifier
Refrigerators Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
