Question about Electrolux Dishwashers
Electrolux EIDW5705 control panel
Control panel does not respond
;dishwasher on loc - cannot release
Hello Ruth, thank you for your post!
From what you have described your Electrolux dishwasher is stuck on loc and delay start continues to operate. I would suggest performing a reset on your dishwasher and you can do that by disconnecting power from it for at least ten minutes. If you continue to experience issues with your dishwasher can you respond back with your model number? You can locate the serial tag (which lists your model number) on the inside left hand wall. With that information I will be happy to help you further. -Matt
Mar 06, 2016 | Electrolux Dishwashers
My stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
Electrolux side by side refrigerator model E126SS55GSO touch pad on ice and water dispenser will not respond to touch, error code of CE on freezer and fridge temperature, alarm keeps beeping non stop. ...
You have a communication failure, check the wiring at the freezer door hinge and if it is ok replace the control beneath the unit if it continues replace the user interface as well.
Sep 22, 2013 | Electrolux Refrigerators
Electrolux side by side E126ss55gso Ice and water control board will not respond to touch, Error codes of CE on ice and water, alarm will not shut off
Sep 22, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux oven in fan mode not heating
Hello tamio - From what you have described either the element needs to be replace or you have a miscommunication with the control panel and EOC not responding. Contact a professional to accurately diagnose and repair the unit.
Sep 29, 2012 | Ovens
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Panel not working on Electrolux Dishwasher
CONTACT ELECTROLUX. YOU EITHER HAVE A FAULTY TOUCH PAD OR A BAD RIBBON CONNECTION.
Apr 02, 2009 | Electrolux Frigidaire Professional Series...
EX600 Electrolux Diashwasher
wanna give the model number if possible, sounds like your're having a problem with the display board malfunctioning, theres a kit available for the fix need to know the model though, any chance this is under 1yr old??
Mar 15, 2008 | Dishwashers
Dishwashers Logo
35 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
