Question about Ranger Ink Glossy Accents - Clear Dimensional Embellishment - 2 ounces
Glossy Accents when dry on art tiles dip in the middle
After spending hours on making art tiles I applied the glossy accents from the outside of my square and then filled in the middle (1" square tile) The tiles wer left on a flat surface in a room where no-one else goes in to. Next day 90% of the tiles had large dips in the middle
    Problem Solver:
  • 5 Answers
Sounds like you're describing what we usually call a 'fish eye' in the paint. It usually comes from a greasy film on the surface. Normally the surface would need to be cleaned/degreased and/or primed before painting. Not sure what was involved in your process of 'making art tiles' but if you painted them with an oil/alkyd/solvent based paint, it could create a 'fish eye' effect if the glossy accents you applied on top is latex/water-based.
Posted on Dec 10, 2013
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
The ink won't dry on glossy paper
It will take longer on glossy paper but make sure that the paper you are using is designed for an inkjet printer. If it is designed for a laser printer the ink will not absorb in and dry properly.
Jan 07, 2010 | HP DesignJet 1050c InkJet Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Ink not dry when printing photographs
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
Black ink rubs off when using publisher 2007 on glossy photo paper with my new canon pixma IP4500
you may need to try photo ink, because normal printing ink doesnt dry quickly on glossy paper.
Aug 29, 2008 | Computers & Internet
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Ranger Ink Glossy Accents - Clear Dimensional Embellishment - 2 ounces Logo
383 people viewed this question
Top Ranger Ink Adhesives, Coatings & Sealants Experts
Richard Piatek
Richard Piatek
David Payne
David Payne
Are you a Ranger Ink Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
