Question about ASUS VK222H Monitor
Searching for signal
When I launch a game the monitor turns black .He turns off .Then every time I have to wait about 10 seconds before the monitor finds signal and everything is okay . This happens when I am using the HDMI . When I am on DVI it says NO SIGNAL then after 10 secs everything is fine . Any solution for that .
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
DVI and HDMI are the exact same signal, except that DVI doesn't include the provision for audio. Essentially the problem you're having is that you have the monitor set to auto input rather than HDMI input or DVI input. Setting the monitor to not look for any input you plug in and defining the input should cause the hunting wait to be eliminated.
Posted on Nov 24, 2013
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: The monitor screen go to black after 5 seconds
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
byteguy
  • 2229 Answers
SOURCE: when i start the computer and the monitor it says
How is the monitor hooked up? Are you using the SVGA plug (blue center with 15 pins) or the DVI (white with a lot of pins)?
Either way, if your monitor says there is no signal, then it means your computer is not putting out a video signal. Depending on you computer, this could mean 1)bad power supply 2)bad video card, 3)loose cable connection.
You'll need to check all three. Since the monitor does display a message, it is probably good.
Posted on Jun 17, 2010
budmrtn
  • 11361 Answers
SOURCE: how can i connect my
You getting no support because the PS3 video resolution is too high for the monitor to display, you need to lower your PS3 VIDEO resolution.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 25, 2010
How to relearn throttle body on a Lexus is250
Pedal Relearn Procedure
Accerlerator Pedal Released Postion Learning is and operation to learnicon1.png the full released postions of the accerlerator pedal by monitoring the accelerator pedal sensor output signal. It must be performed each time harness connector of accelearator pedal postion sensor or ECM is disconnected.
1. Make Sure the acceleartor Pedal is fully released
2. Turn Ignition switchON and wait at least 2 Seconds.
3. Turn ignition switchOFF and wait at least 10 Seconds
4. Turn Ignition switchON and wait at least 2 seconds.
5. Turn Ignition switchoff and wait at least 10 seconds
Throttle Valve Relearn
Throttle ValveClosed Postion Learningicon1.png is to learn the fully closed postion of the throttle valveby monitoring the throttle position sensor output signal. It must be performed each time harness of
electric throttle control actuator or ECM is disconnect.
1.Make sure accelerator pedal is fully released.
2. Turn ignition ON
3. Turn igntion switch OFF and wait at least 10 seconds. Make sure that the throttle valvemoves during the 10 seconds by confrming the operating sound.
(You can hear the TB sound when you have key on and shifter in first gear and step on the gas. So you know what you listening for.)
Idle Air Volume Relearn Procedure
The Following Condtions Must be met in order for procedure to Work.
Battery Voltage :More than 12.9 volts at idle
Engine Coolant Temp 158-203 degrees Farenhiet
Electric Load Switch OFF i.e Air Condition, headlamps , rear defogger
Steering Wheel: Neutral Postion (Straight Ahead)
PNP Switch: OFF (Park Neutral Switch i.e. Clutch Switch...pretty sure)
1. Perform ACCERLEARATOR PEDAL RELEASED POSTIONS LEARNING
2. Perform THROTTLE VALVECLOSED POSITION LEARNING
3. Start engine and warm it up to operation temperature
4. Turn igniton switch OFF and wait at least 10 seconds
5. Confirm Gas Pedalif fully realeased, then turn igniton switch ON and wait 3 seconds
6. Fully step on and release gas pedal5 time within 5 seconds
8. Wait 7 seconds and fully step on gas and stay on until MIL stops blinking and is steady.
9. Fully release the Gas pedalwithin 3 seconds after the MIL has turned ON steady.
10. Start engine imediatly and let idle. Wait 20 seconds.
Sep 22, 2014 | Lexus IS 250 Cars & Trucks
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
Hi! A few months back i bought a Philips 52'' LED-TV 52PFL5605H Full-HD, 100Hz Tv to my computer and it works good. The only problem is everytime(not always. 8 out of 10 times maybe) the screen is just...
Unfortunately the video you are giving the tv must be one of the last systems the uProcessor in the tv checks. It takes about 15 seconds to detect signal/no signal for each system. Good old automated technology!
Dec 31, 2010 | Philips Ambilight 2 52 in. Flat-Panel LCD...
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
2003 nissan altima rpm goes crazy (at 2 then drops to 0, back and forth)then it dies. it is doing it more frequently
I have also read in the service manual that doing an idle relearn helps with RPM problems. This is the procedure below. It is complicated to do unless you have a watch or something to count the seconds with.
DESCRIPTION
“Accelerator Pedal Released Position Learning” is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning UBS002OA
DESCRIPTION
“Throttle Valve Closed Position Learning” is an operation to learn the fully closed position of the throttle valve
by monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch “ON”.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning UBS002OB
DESCRIPTION
“Idle Air Volume Learning” is an operation to learn the idle air volume that keeps each engine within the specific
range. It must be performed under any of the following conditions:
 Each time electric throttle control actuator or ECM is replaced.
 Idle speed or ignition timing is out of specification.
PREPARATION
Before performing “Idle Air Volume Learning”, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
 Battery voltage: More than 12.9V (At idle)
 Engine coolant temperature: 70 - 95ーC (158 - 203ーF)
 PNP switch: ON
 Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, set lighting switch to the 1st position to light
only small lamps.
 Steering wheel: Neutral (Straight-ahead position)
 Vehicle speed: Stopped
Apr 29, 2009 | 2003 Nissan Altima
Apex 1919 tv model brand new and stopped working
I had the same problem. Turned out to be bad capacitor on the main power supply board. The board has a heavy red and black cable at one end and several grey wires at the opposite end. Near the grey cables there are three blue cylinders (two large and one small) surrounded by a black metal frame heat sink. One of the two larger ones was "pregnant" swollen and about to burst. I changed it and the other one like it will new ones from Radio Shack P/N 272-1032 1000 uf 35 WVDC. The unit powered up and worked fine again.
Find a friend who is handy with a soldering iron - parts cost about $3. Be sure to unplug and discharge everything before diving in.
Not a bad little TV/Monitor otherwise.
Good luck
Mar 21, 2009 | Apex Digital LD1919 19 in. LCD TV
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
Open Questions:
ASUS VK222H  Monitor Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
