Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
Beeping Code 9
Beeps 9 times wont move
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 168 Answers
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
Posted on Dec 05, 2013
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
Error code on ltf2140fs2
Hello friend, I appreciate your post!
From my understanding your front load washer LTF2140FS2 is beeping 9 times and then you have to unplug it and plug it back in. When the unit is beeping do you notice any additional lights on the panel coming on? This information would be helpful in assisting you with getting a proper explanation to your current problem. -Matt
Jul 19, 2014 | Frigidaire Washing Machines
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Beeping when I type
If it beeps on every key depression try code s. If it beeps at the end of a word code 1. if it beeps at the same spot space to the right end and press R. MAR key.
DickyO
Nov 01, 2012 | IBM Wheelwriter 3500
Scooter does not move either direction. when i insert the key i get 10 fast beeps and the 9 slower beeps
This scooter has an S drive controller. The beep code will begin with 10 very fast beeps followed by a number of slower beeps. The number of slower beeps indicates the actual code. It will do this only once. To repeat the beep code, remove and reinsert the key.
Beep code #9 is a possible controller trip.
Diagnosis:
The key may have been inserted during battery box installation.
The controller may be overheated.
The brake is dragging or pulling too much current.
Solution:
Remove the key from the key switch before installing the battery box.
If the problem persists shut down the scooter for 10-15 minutes and allow the controller to cool down.
Bottom line is that you may need a new controller or brake. Keep in mind these may be warranty items. A qualified technician may be needed to diagnose and repair the problem. Hope this helps.
Apr 16, 2011 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
My Frigidaire gas range oven wont stay on. It preheats and then the start button blinks and beeps. If you press start button it tries to lock the door. The model # is FGF354BGDD and serial # VF93308104
if range is serveal years old . the oven ignitor may be weak ( it will look orange instead of bright white.) this will start heating and when oven valve cycles it will not keep heat on causing a tempt problem sensed by the eoc( clock) and start beeping . it should also be giving a fault code at this time like F1 / THROUGH 9 . / so oven ignitor is probably at fault .. **** . please respond w/code if it has one so i can help. **** .
Dec 04, 2009 | Kitchen Ranges
DX-800 beeps with Incomplete Info Code = 720
Error Code 720: Cannot connect to the Pop Server. (Incorrect Pop Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the network Administrator
Regarding the beeping noises. The DX-800 has multiple settings for beeps, rings and the dialing monitor. If it is the latter, press MONITOR button once, then press the DOWN arrow, until silenced. Some ringer/beep settings are under Fax Parameters, some are in a special SERVICE MODE.
let us know if you can isolate which one and we can help turn it off. At least now you know what the 720 code means.
Good Luck!
Nov 10, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
BJC-8200 beeps 10 times and wont go online.
  • Hi
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • All The Best: Pineworks
  • Oct 06, 2009 | Canon BJC 8200 Photo InkJet Printer
    My shoprider dasher just beeps
    we just bought a shoprider monaco,after i cleaned it it did same thing just kept beeping,i found moving the free wheeling lever under back bumper a few times cleared it.Lever makes contact with a micro switch,on motor.
    Hope this helps
    Sep 09, 2009 | Shoprider Dasher 9 3 Wheel Scooter...
    Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
    186 people viewed this question
    Top Pride Mobility Products Health & Beauty Experts
    wcdoc1953
    wcdoc1953
    Colin Taylor
    Robin Hill
    Robin Hill
    Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
