Question about Bose Lifestyle 25 System
Bass treble When I turn the bass & treble controls from zero to ten nothing happens to the sound otherwise the system works fine . Thanks
    Top Expert:
  • Bose Master
  • 12,962 Answers
Tone control circuitry is not working. Also check to see if there is a switch on the receiver that renders those controls useless.
Posted on Nov 24, 2013
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
How to adjust tone settings manually for my LG LHT743 DVD receiver? I have several preset settings but no Bass, trebal control
I did some research on this, but was unable to find out how to adjust bass and treble control individually. this is a link to the users manual (not sure if you have or not). You can download it if you like. I did, read through it, and didn't find anything to solve your issue. Unfortunately, this is a common setup for a lot of newer sound systems. Since they are digital, to achieve superior performance, they keep the settings digital and dont allow for fine tuning of the lower and upper frequencies (bass and treble).
http://www.retrevo.com/support/LG-LHT734-Home-Theater-Systems-manual/id/3126dj199/t/2/
I hope this helps.
JD
Mar 24, 2011 | LG LHT734 System
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
I've got a 1999 ford expedition with the Mach radio system in it and it does not have any bass playing thru the front or back speakers and i've changed out the factory amp thats in the back where the sub...
does the new amp you have have a hpf setting if so check to see if thats on, turn off the x-over so it will play both lpf and hpf, bass and treble. are all the speakers wired to the amp aswell, this is the only thing that would stop bass other than the head units settings.
Jun 21, 2010 | 1998 Ford Expedition
Bass and treble not working in dell
Not all hardware supports bass and treble enhancement in ther Std Windows sound controls. unless it worked before I would imagine it isnt supported.
You should be able to enhance it in Media Player using the Graphic Equaliser as this is software based.
Jan 10, 2009 | Dell PowerEdge 1600SC Server
Help
Hi Cassie, unless your receiver is a surround reciever, it won't have an actual subwoofer output. The good news is that you can use either a "line out" jack or a "tape out" jack instead, which most receivers do have. These jacks always have the signal, so there are no special settings to remember - simply operate your receiver as usual. Everything comes out of these jacks, not just the bass - but it won't matter since your subwoofer will only reproduce the bass frequencies. The bass information is generally identical in both left and right channels, so either the right or left jack should work fine, and it's okay to leave the other one unconnected. The only bad thing is the line and tape outputs are not affected by the receiver's bass and treble controls, so you'll have to control the bass volume at the subwoofer if it has a control. If you can't control the amount of bass you hear, turn up the volume and reduce the treble which will give the illusion of more bass. I'm assuming you have "powered" subwoofer (has its own built-in amplifier). Good luck!
Jun 22, 2008 | Bose Acoustimass 15 System
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
No sound , Intermittent no sound
Try this first....try using a contact cleaner on Vol, Treble, Bass controls. With the system OFF, remove the knobs (usually just pull straight out, check for a set screw first) Then using a commerically available contact cleaner which comes in a spray can, squirt some into the area where the shaft enter the pot and turn the shaft a few times as you do. Five it a good blast. Then turn on your system with the controls turned down and see if that worked. The contact in the pots get dirty over time. If this doesn't help then it will be most likely an electrical problem that is out of my expertise.
Aug 20, 2007 | Teac PLD2000 System
Bose Lifestyle 25 System Logo
49 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
