Question about Frigidaire FPHD2491KF Dishwasher
Circulation pump not running - Frigidaire FPHD2491KF Dishwasher
  • Official Brand Answer
  • 4,342 Answers
Hi Dok, thank you for your post!
I'm not sure what you are referring to as the circulation pump; however your Frigidaire dishwasher, FPHD2491KF, does have a drain pump. Therefore, if your dishwasher is water left in sump, then more than likely it would need replacing. Is your dishwasher making a grinding noise? If so, then it would be advisable to connect with a professional to accurately diagnose the drain motor. You can locate a certified technician directly through the manufacturer website or in your local directory to determine what may be causing the issue at hand.
Best regards!
Posted on Nov 27, 2013
Taco 007 circulating pump stays on even though boiler shuts down
Don't know your specific unit, but in general, heating systems are two-stage devices:
1: Its too cold: the motorised HW/CH valve moved to the required position, and on achieving it, the circulaion pump starts and the boiler is enabled. (The circ pump may start immediately - its not usually important.) The hot water from the boiler circulates through the heat exchanger and/or radiators until the thermostat thinks its target is warm enough, whereupon it disables the boiler, stops the pump and closes/relaxes the valve(s).
2: The boiler is off while disabled. When enabled, it heats the circulating water to a 'high' temperature and seeks to keep it there. If it reaches that temperature, the boiler will cycle on and off as necessary to maintain the set 'high' temperature. (The circulation pump must run all the time the boiler is enabled.) This may be what you're noticing. Additionally, some boilers will run the circulation pump for a little while after being disabled to reduce the temperature if the water in the pipes and boiler.
Your question doesn't say how the pump running corresponds to thee thermostat settings, but if it were stuck on, I think you'd know!
Dec 31, 2016 | Water Heaters
No hot water or heating
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though itmay be hot and seem to be running. In this cause the pump can sometimes betaken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in moredetail.
Heating Circulating Water Pump Problems
heatman101
Apr 24, 2011 | Heating & Cooling
My heating is not working properly it starts and then after a while radiater light goes on and off n then heating stop working but i get hot water ok
The next problem is that the pump gets stuck and is not running even though it may be hot and seem to be running. In this cause the pump can sometimes be taken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in more detail.
heatman101
Feb 23, 2011 | Heating & Cooling
Cooker heats water but not rads. What could be the problem Thank you.
heatman101
Jan 26, 2011 | Heating & Cooling
Theres no heat going though the rad
heatman101
Jan 21, 2011 | Heating & Cooling
Motor is wire to be on full cylce rather than circulate.
The wiring is not what makes a pump full cycle or circulate. If the spa motor is always on it is either because the pump relay is stuck closed, or the heater isnt keeping temerature therefor requiring the pump to be constantly running. There are also setting on newer style computer boards which determine a pump to be either "jet" or "circulation" pumps.
Also, a spa pump will run fulltime if the water is below 50 degrees F.
If you need further help, contact me @ adamh@newconceptchem.com
Nov 22, 2010 | Century New Magnetek Pool Spa Pump Motor...
I bought wilo water pump less than a year, when i switch it on it stop working make no sound at all. I wonder what could happen to it. please if you have any idial please let me know
heatman101
Sep 27, 2010 | Heating & Cooling
The pump is unning but not circulating water on my central heating
heatman101
Sep 25, 2010 | Heating & Cooling
Frigidaire FPHD2491KF Dishwasher Logo
156 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
