Question about Toshiba 20AF46 20" TV
PICTURE ! Have great sound, digital cable attached and works but the picture appears to freeze (sound continues) and small little boxes jumping across the screen What could cause this? Recently moved the tv from one city to another by car
    Genius:
  • 1,694 Answers
Digital cable source box at fault.
Posted on Oct 10, 2007
How can I replace the outlet for the cables on the back of my quasar SP 3234E TV?
A "freezing" picture sounds like something other than your television. Do you have a cable box or satellite box attached? They fail sometimes and need to be replaced. (You have an analog TV and "freezing" is a digital problem.)
Jul 22, 2014 | Quasar Televison & Video
I would like to send pictures from my computer and it appears to be quit a task to do so. Can you forward a manual or offer any short cuts to make this a simple task to attach pictures to...
Right-click on the picture and select e-mail client. A box will open and offer you a choice of picture sizes (small, medium, large) ...select one and your e-mail will open with the picture attached.
Feb 14, 2011 | Kodak EASYSHARE M340 Digital Camera
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Picture freezes
this is a great factor with the weather EVEN CABLE TV IS THROUGH SATILLITE !!!! there could be bad weather 50 miles away and it will affect your signal..........
Jun 21, 2009 | Insignia Digital-to-Analog Converter for...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
Several problems
you may want to check all of your coax conections and stray ground shield piece littl tiny silver mtal wire will cause that reaction or you may have a ad reciever if so if ou have the directv inurance they will replace it for no cost to you at all.
good luck
please rate
Jan 11, 2008 | Philips DSR708 DirecTV DTV Receiver /...
Split screen, dark and then light, picture freezes
From what source ? Does it happen when you play a DVD ?
Cable direct? Cable box? Satellite box?..........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
Picture Jumps/flashes for first 5 minutes
There is a module called a hyper board that is vertically mounted near the jack panel. Inside the module are 10mf/25v capacitors they are grtting weak. The module is fully shielded and pluggs into a socket. the module has 4 tabs (2 on each end) that must be unsoldered before it can be unplugged. This repair should be done by a qualified technician. The caps are surface mounts and very small. Unless you have excellent soldering skills and a rock steady hand DO NOT ATTEMPT to repair this problem on your own.
Nov 16, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba theatreview
sounds like vertical problem maybe bad solder connections on vertical ic check and get back to me
Nov 03, 2007 | Televison & Video
Toshiba 20AF46 20" TV Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
