Can't get sound from my marantz sr- 560 to speakers. Help?
Soulvisitor
  • 1113 Answers
SOURCE: Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Posted on Dec 23, 2007
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
cjackHD
  • 71 Answers
SOURCE: Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
SOURCE: Hi there. I have a Marantz SR-82 Receiver that
Hi, try to turn down the input balance knob, I think you have overloadet it.
Posted on Mar 19, 2010
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
Marantz problems
my sound on my marantz av surround receiver sr5003 stopped working, i need help to restore it:
Jan 01, 2014 | Televison & Video
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
I have a Marantz SR7200. I have been using for a long time with 6ch stereo with no problem. Suddenly, it starts to make a lot of noise on front speakers in any mode. It just stops this noise when source...
Hello Sergio.
Sounds like a bare wire (speaker wire) most probably is touching your SR's metal body.
Remove all speaker cables, re-terminate them clean (cut, trim, and twist again) and then re-plug them in to the binding posts.
When you go puredirect, it overcoms some filtering circuits of the board and this should be the reason why it stops.
Try that & advise.
Dec 13, 2010 | Marantz SR-7200 Receiver
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Feb 21, 2009 | Marantz SR-5200 Receiver
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Sep 23, 2007 | Marantz SR-5200 Receiver
19 people viewed this question
 Grubhead
Grubhead
