Question about Schneider 210mm f/5.6 Apo-Symmar Lens with Copal Press 1 Shutter
I cant tune my scneider stv 1403 v tv - Schneider 210mm f/5.6 Apo-Symmar Lens with Copal Press 1 Shutter
I cant get any BBC programs
Check and replace the tuner to this set. It is weak. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 21, 2014 | Samsung LE22B450 22 in. HD-Ready LCD TV
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
32 " STV-328 Spectroniq
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in rectifying the fault.....
May 18, 2011 | Astar SpectronIQ STV378 37 in. LCD TV
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
I need a replacement turntable for my scneider microwave SMW 23-801-4, Could you please help or advise ?
The glass turntables are ~ $30-$40 (+ shipping) and the brand name 'Scneider' doesn't turn up anywhere.
Aug 28, 2009 | Schneider Optics
Whitch one part of the ''WANSA'' TV? STV3325 OR STV 9325
My TV produces an buzzer sound when I switch on. The TV is WANSA TV. Can U advise how to resolve it.
Jun 10, 2009 | Daewoo Televison & Video
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Cant tune my Sony TV to channel 3
Go into the setting menu on the tv and go to channel setup,then select add channel.
please rate this solution
Feb 01, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Cameras Logo
Top Schneider Cameras Experts
Are you a Schneider Camera Expert? Answer questions, earn points and help others
