Question about Nokia Lumia 800
Battery heat up quickly on Nokia Lumia 800
When i am listening to my music on the phone the battery heat up quickly (get really warm) while going on apps , the battery drain out quickly. what should I do to solve this.
  • Nokia Master
  • 2,072 Answers
This is fairly common with heavy use. If it is hot even to where you can't keep your hand on it, then you may want to replace the battery. If you can keep your hand on it without hurting yourself I wouldn't worry about it.
Posted on Nov 23, 2013
  • Anees Yaquoob Nov 24, 2013
    It only happen when i plug in headphones into the phone . it heat up quickly when i make a phone call or listening to much that when battery burns out quickly.
  • Justin
    Justin Nov 24, 2013
    This phone only has a 1450mAH battery in it which you'd be lucky to get half a day's use out of it. My Samsung Note II has a 3100mAh battery. Over double the battery life.
4 Suggested Answers
Service Dude
  • 201 Answers
SOURCE: My NOKIA 5310 is heating up + battery drains in 3 hours,
it realy soun sounds like liquid damage, take it in for repairs, if you wnat to try youreself open the phone wash it with metholated sprirts and see you should be able to see the damage white powder like
Posted on Dec 07, 2008
nainamainaka
  • 380 Answers
SOURCE: know if my lumia 800 is locked or not
If you look at the IMEI/Barcode label on the Lumia's box it should tell you what version it is, probably in the right corner.
If it says "UK CV" or similar then it's unlocked, if it mentions a network like Orange, three etc then it's probably locked.
Also if the phone has a networks logo on the screen during boot up this is also a sign that it could be locked.
Try using a SIM card from a different network.If you can, it's unlocked.
Posted on Feb 29, 2012
SOURCE: free unlock nokia lumia 800
unlock my noikia lumia 800 orange london
Posted on May 26, 2013
My battery drains very quickly, huawei g8. Which apps can i close from the huawei installed apps?
Facebook drains the battery. So i suggest you close that one. But to completely save your battery, you can get an app that completely does wonders. The app is called Greenify. Its very helpful.
Nov 12, 2016 | Huawei Cell Phones
My Nokia 701 just heats when am charging and sometimes it looses its memory, what could be the proble?
Phones plugged in for charging generally do heat up because smartphone current consumption likely to warm up the battery.
If the phone heats up when not charging you probably have many apps running in the background which in turn causes loss in memory.
Long press menu key and close all unwanted running apps by touching X mark on them.
Switch off your Bluetooth when not in use.
Do not store your data (camera photos, music, videos etc) in the phones internal memory instead transfer it to your external SD card.
Check if your using the latest firmware for your phone which might help solve some issues related.
Feb 09, 2015 | Nokia Cell Phones
Lt25 battery drain
backup your data and try to factory reset your phone. try the phone without reinstalling accounts and apps. if ok, try to reinstall accounts and apps.
Dec 14, 2013 | Sony LT25I XPERIA V 4G LTE QUADBAND...
Battery overheating and draining
i think ur phone problem some short circuit problem thats y battery quick draining
Dec 04, 2013 | Samsung Galaxy Cell Phones
Zte z990 phone keeps shutting itself off
Well, it really depends on many factors. I guess that you are using many apps at the same time (Background apps consume battery).
Another possibility is that your battery is asking for a retirement. Replace it and see if the problem persists. You may need to take it to the repairman.
Oct 24, 2012 | ZTE Avail Z990 - Black at&t Smartphone
How can i install a dictionary on my nokia 5130 xpress music?
Go to www.getjar.com and locate your phone model and corresponding dictionary and download and install on your phone, free. Make sure you have the right language dictionary as there are many dicts in many languages.
Sep 26, 2009 | Nokia 5310 Cellular Phone
Nokia n73 new battery charges quickly and
try without memory card and if problem persists pls go to customer care...
Aug 10, 2009 | Nokia N73 Cellular Phone
Battery life dies out quickly on Nokia 6301...
if you have had your bluetooth on or have been listening to music for a long time that can drain the battery very quickly . the other problem could be if you are not lettting it die of totally then charging it the battery remembers so when you do charge it the battery dont last long . try turning your bluetooth off or just lettin your battery die off totally then charge it fully
Aug 07, 2009 | Nokia 6301 Cellular Phone
Phone is heating up very soon
I may know the problem, in my opinion there could be two possible things worng with your "Nokia 5800". One is that your fan(inside the phone) is not working properly. you should get it checked at your local cell phone repair shop. the other less likely problem is that you have a wrong type of battery in your phone. witch can also be fixed at a cell phone repair shop
Jun 30, 2009 | Nokia 5800 XpressMusic Smartphone
I was listenning to music and the phone shut off now it can not open
hello there! there are really some instances that cellphones shut down if listening to music, one of its causes is, battery is not that sufficient enough to allow you to use it. and another thing is, you might be using the other programs while listening to music..such as you are texting or using the internet in your phone. it will really allow disconnection of one program to another causing it to shut down. thanks!
Apr 11, 2009 | Apple Cell Phones
Nokia Lumia 800 Logo
98 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
