Question about Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna 125b leaf blower
Replaced carburetor and filter still won't stay running
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Have you checked the Flame Arrester in the Muffler. They clog easy and engine can't push out exhaust.
Posted on Nov 23, 2013
Testimonial: "Cleaned flame arrester and even took off the exhaust it still only runs when I prime it a lot till the gas burns out of the carb"
  • 6 more comments
  • Donald Kuda
    Donald Kuda Nov 25, 2013
    Cleaned flame arrester still have same problem only runs when I prime it burns off what's in the carb and shuts off
  • wadingriver
    wadingriver Nov 26, 2013
    Ok must be Fuel lines. The Ethanol gas beats the heck out of fuel lines .
  • Donald Kuda
    Donald Kuda Nov 28, 2013
    Thank you for getting back to me I changed all the fuel lines and it has not worked
  • wadingriver
    wadingriver Nov 28, 2013
    New Carburetor, new fuel lines, no Exhaust clog AND it only runs on Primed fuel then stalls...are you sure you didn't reverse the Fuel lines to the Carb?
  • Donald Kuda
    No took them off one at a time when I replaced them. Almost feel like the new carb I got might be bad
  • wadingriver
    what's left??? nothing! short burst of life from the engine from what you pump in and then it dies. I tend to agree.. possibly a bad carb.
  • wadingriver
    you are choking the engine with the throttle of Full , right?
  • Donald Kuda
    Yes doing exactly what the manufacture calls for
spekgt
  • 60 Answers
SOURCE: how do you install primer bulb on husqvarna 125b
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
Posted on Aug 29, 2009
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
rwvanlue
  • 486 Answers
SOURCE: my leaf blower will start but wont run
fuel system needs cleaned
check fuel lines
filter
remove carburetor for replacing diaphragms/gaskets
Posted on Nov 08, 2009
  • 430 Answers
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
Posted on Nov 23, 2009
SOURCE: I have a Husqvarna 125B leaf blower with less than
run for 10-20sec. cut off
Posted on Nov 06, 2010
Husqvarna 125b won't prime and run unless upside down. If turned right side up it dies. If I prime it when it's right side up it blows bubbles in the tank.
Try a new gas cap. There needs to be air behind the liquid in a vacuum (think plumbing) or it does not flow. Make sure you've replaced all the cracked lines. Allowing air into the vacuum will also stop the flow. It's one of these.
Sep 13, 2014 | Husqvarna 125B 28CC Gas Leaf Blower...
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
Aug 31, 2014 | Husqvarna 28cc Hand Held Blower HVH 125B
What are the screw adjustments for the carburetor for 125B Grass Leaf Blower?
These should be set by a certified dealer using a tachometer. It is against Federal law to tamper with the adjustment screws. You can also damage or destroy the unit if they are not set properly.
Jun 13, 2014 | Husqvarna Hand Held Blower 125 B Grass...
Husqvarna 125b trigger stays on full
There is a manual lever on these that holds the trigger at different settings. Check and if it is full on, move it to the other extreme.
Nov 21, 2013 | Husqvarna Hand Held Blower 125 B Grass...
Weedeater blower will not stay running
how long will it run? 30 seconds 10 min.
pour ot the gas & look inside the fuel tank is it dirty?
is the filter still hooked up to the supply line. Mine had fallen off [worn out] I replaced with new fuel lines and still had a 20 sec run. It was flooding let me know
Sep 02, 2013 | Husqvarna 28cc Hand Held Blower HVH 125B
Have a husqvarna 125b have spark and fuel wont start done every thing i know new plug rebuilt carb gaped coil im tired of pull on it any answers please help it
the rule of thumb is spark, fuel, compression. I found I gad a plugged air filter. It would not start until I removed it and tried to start.
May 07, 2012 | Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Aug 02, 2011 | Husqvarna Hand Held Blower 125 B Grass...
Nov 22, 2009 | Husqvarna Garden
My leaf blower will start but wont run when i give it gas it dies. Huskvarna 125B
check fuel lines
filter
Nov 08, 2009 | Husqvarna Garden
Husqvarna 28cc Hand Held Blower HVH 125B Logo
334 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
