Question about HP Photosmart C6100 All-In-One Printer
Que will not purge - HP Photosmart C6100 All-In-One Printer
Ayuda tengo una mercury villager 1999 y mi problema es que me esta acumulando gases en el tanque de combustible quito el tapon de gasolina y salen los gases..ya revise las mangueras de vacio y las que ban...
si dejas bajar el tanque al minimo el tanque queda vaco y por temperatura va a generar presion si no da codigos el systema de raciclaje de gases supuestamente esta trabajando
Nov 07, 2014 | 1999 Mercury Villager
How do I cancel all qued prints
Here is a step by step guide that will show you how to stop the print que so you can purge the print jobs in the que.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Jun 07, 2013 | HP Office Equipment & Supplies
I can't print the items in my printer queue. How do I get them to print?
It sounds like you have a print job stuck in the print que. When this happens the print jobs after the stuck one will not print either. You will need to clear the print que and reprint the jobs. Here is a link to an article showing how to purge the print que and get your printer back printing again.
Apr 14, 2013 | Lexmark X7350 All-In-One InkJet Printer
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
MY HP OFFICEJET 6000 E609A SERIES 7 KEEPS PRINTING A TEST PAGE BEFORE ANY PRINTOUT. HOW DO I STOP THIS?
Thank you for using FixYa
This is a common issue. What you will need to do is purge your print jobs. You may find an Icon on the task bar for the printer, click on it and highlight the documents in the list and cancel them. Sometimes you need to turn off the printer first and then purge the jobs in que. You could also go to the start button and control panel and select the printer and purge it.
I hope this was useful and please comment if this was helpful to you.
Mar 13, 2011 | Computers & Internet
Unable to print 51 That is what it listed on my Brother MFC665cw. I love this wireless printer and do not know how to fix it. It was working perfectly and then later when I went to print something,...
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Apr 06, 2010 | Brother Multi-Function Center MFC-665CW...
Tengo problema con impresora mfc210c en la pantalla dice eror36
El error 36 es cuando el Purge unit de la maquina esta lleno, hablando claro es una esponga que recoje el residuo de tinta y es contabilizado por la maquina, ella asume que ya esta lleno y nesecitas remplazarlo.... en este caso nesecitas visitar un dealer brother o taller.... www.brother.com para mas inf. sobre un dealer autorizado...
Oct 03, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printer does not print error mes. unable to clean
you need a nwe waist ink absorber which can be purchased at any service dealer near your home (see www.brother.com)
Apr 05, 2008 | Brother MFC-3240C All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
