Question about magicjack.com Computers & Internet
Won't work with new router
I have a new wireless gateway router from Comcast (Technicolor TC8305C) and now my Magicjack wont't work. I keep receiving error 23. Everything else works fine.
  • magicjack.com Master
  • 2,219 Answers
On your softphone, please do the following:
1.Click "Menu" on the top right-hand corner
2.Click "Advanced Users"
3.Click "Restart"
If your magicJack is plugged into your modem or router, unplug it from the power source, wait 30 seconds, and plug it back in.
If that does not work:
<Requires some technical understanding. Explanation below. >
Please open port 49152-65535 UDP on ALL firewalls and your router, if you have one. (Router ports can be opened via the web
application applicable to your router).
Restart magicJack again by following the steps above.
How to access Web Application for router
1.Start > Run > Type in cmd > Press ENTER
2.A command prompt will open
3.Type ipconfig > press ENTER
4.Make note / write down name of the default gateway and IP address
5.Open your Internet Browser
6.Type in the default gateway IP (Example: 192.168.1.1)
7.Type in Username and Password
8.Find "Port Forwarding" and Forward Port 49152-65535 UDP for the IP address you located earlier.
Posted on Feb 04, 2015
2 Suggested Answers
SOURCE: fax magicjack
  1. Operating Systems
    • As of 2010, the Magic Jack works well with Windows XP and Vista machines. Windows 7 has reported problems listed on their Microsoft Answers forum.
    Do Not Support
    • According to the Magic Jack company website they "...do not officially support using faxing with Magic Jack."
    Testing the Fax
    • Test your fax machine with Magic Jack by turning off the error correction on the machine and using the slowest speed available. If successful at that speed, increase the speed and check if it continues to work.
Read more: Does Magic Jack Support Faxing? ' eHow.com http://www.ehow.com/facts_7148239_magic-jack-support-faxing_.html#ixzz1tntAK093
Posted on May 03, 2012
What is the best modem to connect to the internet via VPN?
This is a known issue with that modem and Comcast wont support VPN from residential installations. If you want to change modems that don't have this issue, get a Motorola surfboard. If you want to change settings on the one that you have because of the protocols for assignment of addresses let me know
Jul 31, 2014 | Computers & Internet
How do you reset a technicolor router
Usually there is a labeled recessed reset button on the rear of the device, near the AC jack connector. Try here for a User Manual: http://www.technicolor.com/en/hi/digital-home/mediaaccess/dsl/wireless/adsl/technicolor-tg582n
Apr 30, 2013 | Computers & Internet
I had ATT DSL and I changed it to Comcast cable. My main computer works but my laptops don't work because of the router
ITS PRETTY SIMPLE.... DO A SOFT RESET IN THE ROUTER AND DO A MAC CLONE. CONFIGURE THE WIRELESS SETTINGS
Jan 07, 2010 | Gateway Wireless-B Router (wbr-100)
How can I my up my comcast netgear modems wireless to work? when I try my PS3 it detects a sginal but wont obtain an IP address. The same with my lap top.
You have to change the ipddress on the router different then the modem. For example 192.168.9.1 and leave the modems ip alone. Plug the cable into the Lan port of the router. Go to the setup screen on the router and tell give your username and password that
Comcast gives you. You will need comcast gateway address and dns numbers. There will be a connect button on the router and tell it connect it to the modem. You are trying to let the router receive that only ip address.
Nov 09, 2009 | NetGear CG814M Wireless Cable Modem...
Can a actiontec gateway wireless DSL router be connected to a comcast cable modem?I have an old DSL wireless router (gateway), can I use this as my wireless router with comcast cable internet, or do i need...
You could do it, but it's a bit of a pain in the ***** and probably not worth the hassle.
Actiontec DSL gateway was not designed to act as a "proper" router and therefore you won't be able to make it act like one permanently (well, unless there's a hacked firmware out there somewhere ;).
Of course, since it runs linux, you can telnet into it and manually set up the ip addresses on both wireless/wired interfaces and the necessary route between them. It will then work as a wireless access point for your comcast cable modem, but any changes will be lost every time you reboot the actiontec.
I've done it in the past with similar setup but quickly got tired of having to console the actiontec to add the ips and routes every time it crashed -and eventually got a proper wireless router.
So-it can be done, just not easily.
Have fun,
Raf
Nov 08, 2009 | Actiontec (GT701WG) Wireless Router
Use 2700 as router only?
there's a way to make the gateway act as a router only but it's not really recommended since there's a possibility that the connection will not be as stable as it should.
anyways you can try the following steps in making your gateway act as a router (not really a router but just a switch and a wireless access point).
- access the router's web user interface by typing http://192.168.0.1 on your web browser
- then click on the "Advanced Configuration Settings"
- select the "Transparent Bridging" option (note: you must configure your wireless settings first before trying these steps since you might not be able to access the gateway's page anymore once you save the changes)
- set the vpi to 0 and vci to 32 if it asked you for those settings. next to 'ATM PVC Search' select the radio button next to Disable. ensure Bridged LLC is selected next to 'ATM Encapsulation'.
- then save the settings
- connect now the new modem to one of the ethernet ports of the 2700hg-d using an rj-45 or an ethernet cable
hope this'll help you.
Jun 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Became new customer to comcast-got the bundle package, internet,phone,cable. Voice overlay modem to accomodate internet and phone lines. Did not use their wireless router-using exsiting router D-Link model...
Hi jad123,
I am sorry to learn about the problems you are experiencing with your service.
I will be happy to reach out to my contacts to assist you in resolving this issue. Please feel free to contact me so that I can get more information from you.
Thanks in advance!
Mark C.
Comcast Executive Offices
We_Can_Help@cable.comcast.com
Apr 10, 2008 | Computers & Internet
Computers & Internet Logo
152 people viewed this question
Top magicjack.com Computers & Internet Experts
General Systems...
David Payne
David Payne
ka4iup
ka4iup
Are you a magicjack.com Computer and Internet Expert? Answer questions, earn points and help others
