Question about Asko Dishwashers
Care anchor The dishwasher is falling out of the cabinet. How do I anchor it at the top?
  • 31 Answers
Open door and look up under the lip of the counter there is 2 metal tabs with holes in them. You have to put screws in them and adjust your feet to help support it. they thread in like a screw and should turn by hand.
Posted on Nov 23, 2013
2 Suggested Answers
  • 25 Answers
SOURCE: BOSCH SHV68 DISHWASHER
All D/W should have what they call a high loop to help prevent back flow from sk to D/W. you can remove the rubberband and place the hole at the bottom take the drain hose run to top of cabinet and fasten will be fine for high loop any excess hose just tuck out the way
Posted on Jan 25, 2008
AEG dishwasher integrated Model newly installed but when I lower the door to load it the dishwasher moves out from under counter and then wont close properly how do I solve this problem?
The built-in dishwashers are almost fixed by screws in top or by side. Carefully read the installation manual where it is explained in detail how to fix the dishwasher under the kitchen worktop. You also need to adjust the height by using the swivel legs that will additionally fix the dishwasher.
Dado
Jun 24, 2017 | AEG Dishwashers
DISHWASHER FALLS OUT OF WHATEVER IS HOLDING IT IN PLACE WHEN RACKS ARE PULLED OUT TO LOAD
It is supposed to be anchored at the top to the counter. You can still operate without anchors.
Aug 04, 2015 | Dishwashers
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
We are installing a dishwasher--have it hooked up but can't seem to get the leveling legs loose so we can adjust the height. Also, the anchoring peices of metal stick out farther than our countertop.
Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Sep 18, 2011 | Frigidaire FGHD2433K 24 in Builtin...
My dishwasher's top rotating sprayer keeps coming loose. The screw and plastic bearing fall out and I think that it has stripped out the end where it seats into the top of the washer. Any ideas on how to...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 21, 2010 | Dishwashers
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Dishwasher: How are the under-counter screws anchored when there is no room to manuver?
For the most part undercounter units are free standing I.E. anchored to nothing, however if a unit is hard plumbed to the water supply or a PVC drain it may seem it is anchored. Most units are just a pain to get a hold of and pull out if they have no rollers.
Bottom line is you got to find a way to pull it forward or tear out a section of cabinet to access the area you need to service if it has no front lower cover.
Jan 03, 2010 | Whirlpool 24 in. DU915PWP Built-in...
How do you anchor the dishwasher so it doesn't move around? There are no brackets on the front to anchor to the counter.
Open the door and look at the top edge of the washer. It should have 1 or 2 small straps to screw down to the cabinet. If no straps look for small holes to screw a piece of metal strap to the cabinet.
Nov 02, 2009 | Dishwashers
Built in dishwasher is not anchored and comes forward when opened
The solution I've seen is to epoxy a 1/2" thick board under the countertop (clamp it firmly to hold it for 24 hours to allow the epoxy to set) and use it as the dishwasher anchor point.
If you don't have 1/2" to work with, remove the lower panel and adjust the legs down to allow more space between the top of your dishwasher and the bottom of the cabinet.
Some higher end dishwashers have holes in the side to anchor it to the cabinets to the left and right of it instead of the top.
SG
Apr 06, 2009 | Kenmore Dishwashers
Jan 17, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
46 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
