Question about Garden
Not getting oil to blade tried the screw to adjust but still no oil getting throu !!
    Scholar:
  • 136 Answers
Your worm gear assembly is probably frozen in with sawdust and dirt. Take off the oil gear assembly. You will need to take off the clutch and the sprocket, the worm gear is directly underneath. Sometimes they are made out of plastic, sometimes of bronze. They use plastic for newer saws. If the gears do not turn easily, when you use your finger to turn them when they are off. then it is probably a good idea to buy a worm gear and then totally clean the assembly. Put in the new gear and it should work. Also check your chain bar check that the hole is clean. They also have a seal around the worm gear under the clutch assembly. It is good that you replace that too.
Posted on Nov 23, 2013
How do I adjust the amount of oil that goes on the blade. It seems to dump a lot of oil on the blade and blade guide. Goes everyplace
Sorry but this model is not equipped with an oil flow adjustment screw.
The clutch cover area must be saturated with lubricant to properly lubricate the bar and chain and
to ensure the long-term durability of your chain saw.
One thing you could try is to purchase a slightly thicker oil. I got some once at a auto part store and it had anti-sling ingredients.
Mar 29, 2014 | Poulan PRO Chainsaw. PP5020 20 in. 50 cc...
My clippers just stopped working...just gives a light buzz
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
Mar 20, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
How to adjust the oil pump on a 350,do u have to tke the clutch off to do so??Pete
No, the adjuster is on the underside of the crankcase, just below the sprocket, it is a bronze coloured screw.screw out to increase the oil flow with a flat bladed screw driver.
Jul 09, 2011 | Garden
The clippers are back together but are cutting the skin and still dont sound right did i put them together right.
Did you remove the comb and blade only? If so, the comb (the part that doesn't move and is closest to the skin) should extend beyond the reach of the blade (the part that does move left and right). Nicking is sometimes caused by excessive pressure against the skin. A properly adjusted blade will resemble someone with an underbite (extended lower jar) with the comb part extending beyond the blade.
Most clippers have a clatter adjustment screw. Turn this until the clipper clatters (buzzes really loud) and then adjust it back until the clatter stops (but not too far or you will lose power and the blade will stall or cut slowly). Be sure to oil the blades. Mineral oil (from a drugstore) will do if you can't get shaver oil.
Good luck from Detroit, MI
Apr 29, 2011 | Vacuums
Does the husq 440e have an oil adjustment on it?
Hi mwaltz48,
Yes, Huskys have a screw adjustment on the bottom, under the chain sprocket assembly.
While looking at the bar side of the saw, turn it over and you'll see a screw that has 3 positions.
Turn the screw to the right will decrease the oil flow, left to increase it. If you put a longer blade on, you should increase the oil flow.
A way to check your oil flow is to run the saw with the blade pointing at something light, such as a freshly cut chunk of wood, or the end of a log, etc. You should see a light line of oil appear.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
Hair stuck between blades...repeatedly
They are garbage.....it's a common problem. Call the manufacturer
Aug 01, 2009 | Andis 01690 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
