Question about Smeg WD16BA Front Load Washer / Dryer
Anyone know what error code 06 means on my smeg wdf16bax1
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
Smeg WM72141BK LEDs flashing 4 times
E4 is water temperature probe short or interrupted.
Apr 21, 2014 | Washing Machines
Smeg DW167.1 error code
I HAVE A SMEG DW167.1 AND IT COMES UP WITH A E9 FAULT, DOES ANYONE KNOW WHAT I CAN DO TO SOLVE THE PROBLEM ,THANKS
Jun 22, 2012 | Smeg Dishwashers
Don't know what the symbols mean
Here is a link for the manual. Page 8 describes what the functions are.
http://www.smegtech.com/site/smeg/pdf_libretti/914773713-GB.pdf
Sep 30, 2009 | Ovens
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Smeg wm16aaa error code e06 Can anybody help me on the above please
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Error code e14
E14 Dryer temperature probe in short circuit or interrupted
Jan 29, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WD16BA Front Load Washer / Dryer Logo
Top Smeg Washing Machines Experts
Tom Chichester
Jorge Rendon
Jorge Rendon
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
