Question about GE GXRTQR GE SmartWater Inline Filter Replacement Cartridge
Cannot remove old quick connect GE GXRTQR filter
I am trying to install a new water filter and water wont stop gushing
There is an oring ( black washer that looks like a black band ) that is not in place . You must have that to keep it from leaking.
Mar 01, 2013 | GE Smartwater Refrigerator Ice Maker...
I have a Leisure HJA6100. The ice dispenser has stopped working.
Yes indeed... but much depends on how hard your water is and the condition of your pipes feeding to your ice dispenser... pipe rust and particles = clogged filters.
I tried to find a schematic diagram to see if there is a water pressure sensor switch somewhere, but no luck... sorry... it was a thought.
But I discovered your filters are quite expensive and none are to be found on eBay and that's highly unusual! One filter will cost you about $60 ~ no thank you.
I would do my best to remove that filter MOUNT and install a "inline" filter that will do the same job and for a LOT less. Add few PVC adapters, maybe a short length of copper line and 2 rubber sleeves and you are back in business... at least filter-wise.
Extend the lines and you can place that filter almost anywhere. The second link shows your FILTER MOUNT... and looking at this photo it looks like it can be a fairly easy job.
You do not want to keep hunting and paying $60 and more for "exotic" water filters so here is a decent GE GXRTQR Inline Filter, 3-Pack for $22.88 including shipping.
Anthony
FILTER HEAD (to gather a few adapters)
Leisure HJA6100 Water Filter Head
eBay 3 Pack FILTERS
GXRTQR Inline Filter 3 Pack eBay
ASSORTED PARTS
Leisure HJA6100 Fridge Freezer Parts Replacement for GE
Dec 02, 2017 | Refrigerators
Change fuel filter
Remove the screw from the metal bracket that is holding the fuel filter. It is located right below the battery to the right. To get the quick connect fuel line fittings off. YOU WILL NEED A DISCONNECT TOOL. O'Reillys or Auto Zone should have the tool pack of (6) The small gray one fits the 2001 Sportage. Put the plastic tool under the fuel line fitting and squeeze together. The fuel line will pop off the old filter. To remove the rear fuel line, go under the vehicle and use the tool on the fuel line. There is a rubber hose with 2 quick connect fittings. One end attaches to the filter and the other end attaches to a metal fuel line under vehicle. Remove the fitting that attaches to the metal line since there is no room on the back of filter for the tool to fit. Once you get the whole assembly out of the car.... you can work on getting the fitting off the rear of the old filter. Be very careful not to damage the plastic quick connect fittings! KEEP YOUR FACE CLEAR OF THE FILTER A SMALL AMOUNT OF GAS WILL COME OUT!!!!!
Feb 28, 2012 | 2001 Kia Sportage
Where is the fuel filter located on a 2002 Kia Sportage?
The fuel filter is located right below the battery to the right. If you intend changing it, here are a few steps to help. Firstly, remove the screw from the metal bracket that is holding the fuel filter. To get the quick connect fuel line fittings off, you need a disconnect tool. I got a pack of 6 at Advance Auto for $12. The small gray one fits the 2001 Sportage.
Put the plastic tool under the fuel line fitting and squeeze together. The fuel line will pop off the old filter. To remove the rear fuel line, I had to go under the vehicle and use the tool on the fuel line. There is a rubber hose with 2 quick connect fittings. One end attaches to the filter and the other end attaches to a metal fuel line under vehicle. Remove the fitting that attaches to the metal line since there is no room on the back of filter for the tool to fit. Once you get the whole assembly out of the car, you can work on getting the fitting off the rear of the old filter. Be very careful not to damage the plastic quick connect fittings!
Jan 16, 2011 | 2002 Kia Sportage
Where is my fuel filter located?
Check under vehicle follow the fule line from the tank
For replace it, lift drivers side of vehicle safely, remove battery ground cable, Using metric wrenches, remove one side of the fuel filter hex nuts( have a large drain pan underneath). On the other side of the filter are 'quick clip' connections. Grasp the ears of the connections and squeeze together and then push the connection toward the old filter and then quickly pull apart.Reverse the procedure.
I hope this helps (remember rated and comment this).
Aug 21, 2010 | 2003 Chevrolet Blazer
I can not locate my charcoal filter in my GE Spacemaker Profile JMV2070BH02 where is the charcoal filter
Charcoal filter is behind the grille at the top of the oven. Find screws in front or at top of the grille and remove them.  Remove the grille by shifting to one side and pulling forward with the door open.  You should see a slot where the filter is inserted.  Remove old filter and replace with new.  Note which side of old filter is up and position the new one the same way.  The filter sits on tabs at the side and back.   Replace grille and screws.
Jun 02, 2009 | GE JVM1440 Microwave Oven
Fuel filter repacement 2007 freestar
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
  1. Release the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Disconnect the 3 fuel tube-to-fuel filter quick connect couplings. For additional information, refer to Section 310-00 .
Disconnect the quick connect coupling from the tube.
  • Press the quick connect coupling release button and separate the quick connect coupling from the tube.
  1. Remove the 2 fuel filter shield pin-type retainers and the fuel filter shield.
  1. Remove the fuel filter assembly.
  1. To install, reverse the removal procedure.
Apr 08, 2009 | 2007 Ford Freestar Limited Minivan
Water sprays out of filter spout when I remove water filter
noremally you would take and shut off the water too the filter and relleive the pressure before you attempt to remove the filter.
Dec 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
How to disconnect water filter
were talkin about the inline water filter with 2 connections on either side of cylindrical filter???pushing in on the tabs should make the "quick release". don worry about breakin they come with the new replacement filter, as do the instructions for installing
Mar 28, 2008 | Refrigerators
GE GXRTQR GE SmartWater Inline Filter Replacement Cartridge Logo
66 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
