Question about ASUS Z71V Notebook
4 beep on dell xps 15 l502x - ASUS Z71V Notebook
What is dell xps error code 2008-0333?
No sure never seen 2008 ..2000-0333 on a desktop is suggestive of video card. If you got this by running ePSA, there should also be a validation code. Any beeps or post lights when pc is first starting.?
Aug 23, 2014 | Dell Computers & Internet
Change hard drive
Pull a black cover on the laptop left side, unscrew 4 that atached the hard drive, pulled and set the new one.
Jun 06, 2014 | OEM Systems Dell Xps L501x L502x Laptop...
DVD will not read any type of disk.
If there is an EXCLAMATION Mark for the DVD, the device could just be failing on you.
Mar 05, 2014 | OEM Systems Dell Xps 15 L502x L501x Blu...
Dell xps 15 L502X laptop
If the display is not working, you should be able to connect an external monitor to it via the laptop's HDMI port. If this is an older laptop, it might have a VGA port instead of an HDMI port. If so, use that instead.
When booting, hit F2 to get to the BIOS.
Oct 31, 2013 | Computers & Internet
Dell xps 15 L501x sub woofer giving crackling sound
hi you can detached or disconnected the subwoofer cable, for temporary or permanent fix, as the speaker sound also produced good quality sound..
here how i disconected the subwoofer cable, it easy to find at the bootoom, see also utube video inside the link given below
http://atozcs.net/dell-xps-l501x-subwoofer-produce-distorted-crackle-sound/
Aug 09, 2013 | Dell Xps 15 L502x Subwoofer Speaker Pn57g
Continuous beep/crackled audio
Beep noise you hear is a BIOS Beep Code
The computer's way of letting you know something is wrong, and an area to look into for it.
Loud and continuous beep, usually indicates a problem with the Processor (CPU).
To be more specific the Processor is overheating.
More specific than that, it is caused by the laptop is dirty inside.
Air is used to cool the hardware components inside the laptop, with the cooling system.
The two hardware components that give off the most heat, is the CPU (Processor), and graphics chipset. (GPU)
The cooling system consists of;
1) Fan Assembly
2) Cooling Tube
3) Heatsink
http://www.parts-people.com/index.php?action=item&id=11931
Click on the image to enlarge.
The aluminum die-cast metal plate you see to the far right, sits on the Processor. (CPU)
The small metal plate is connected to a Cooling Tube.
The small aluminum metal plate to it's left, sits on the graphics chipset. (GPU)
As you can see it also is connected to a Cooling Tube.
Both Cooling Tubes end in a black rectangular finned, Heatsink.
What is not seen of the cooling system, is the Fan Assembly,
http://www.parts-people.com/index.php?action=item&id=10804
The flat part of the D-shaped shroud, of the Fan Assembly; rests up against the finned rectangular Heatsink.
A) The Cooling Tubes are a slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
B) The Cooling Tubes end in a finned Heatsink. A thin small strip of metal, that has tall thin fins protruding from it.
C) The Fan Assembly consists of a small multi-bladed fan, encased in a D-shaped shroud.
The fan draws air up from the Center, (Bottom of laptop), and exhausts the air through the fins of the Heatsink. (Then out the side of the laptop)
Heat from the Processor, and graphics chipset, is absorbed by their small respective metal plates, that sit on them.
The Cooling Tubes then absorb the heat from the small metal plates.
The Cooling Tubes transfer the heat up to the finned Heatsink.
The Heatsink absorbs the heat, then radiates the heat away with it's tall, thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
When the fan blades, center hub, and surrounding cage, (Shroud), get dirty; the cooling capacity drops tremendously.
Just a light coat is all it takes.
When the fins of the Heatsink are clogged with 'Gunk', the cooling capacity drops tremendously.
Gunk = Dirt, dust, lint, hair, food crumbs,.......you name it.
Also in-between the small metal plate on the Cooling Tube, and the Processor; is Thermal Paste.
The top of the Processor, and the bottom of that small metal plate on the Cooling Tube; are not perfectly smooth.
A magnified view would detail, 'Ridges, Valleys, and Pitholes'.
When the two parts are mated together, there are air pockets formed.
Thermal Paste fills these imperfections, and is an Excellent conductor of heat.
In-between the graphics chipset (GPU), and it's respective small metal plate, a small piece of Thermal Pad is used.
A Thermal Pad is a material that is impregnated with Thermal Paste.
After time (Age), and also due to overheating; the Thermal Paste can dry up.
Looses it's thermal conductivity properties.
Same goes for a Thermal Pad, as it's Thermal Paste dries up.
After cleaning it is suggested to replace the Thermal Paste PROPERLY, and replace the Thermal Pad.
A Thermal Pad CANNOT be reused.
Do NOT care if it looks like new.
Once the impression is made into it, from the small metal plate, it's DONE. Small metal plate will not contact, the Thermal Pad's surface correctly again. REPLACE.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503
http://www.hardwaresecrets.com/article/274
http://www.newegg.com/Product/Product.aspx?Item=N82E16835230030
Suggest use a can of compressed air for computers, Tweezers, and a small soft brush. (Makeup brush?)
This is an example of what a dirty laptop looks like inside.
Using the Dell XPS M1710 for an example,
http://www.youtube.com/watch?v=AkAeE5I5E_A
This is Dell Support > XPS 15 (L502X) Notebook PC > Main Support page,
http://www.dell.com/support/troubleshooting/us/en/19/Product/xps-l502x
Click on the Manuals & Documentation tab.
(Product Support / System Configuration / Drivers & Downloads / Parts & Upgrades / Manuals & Documentation / etc )
Click on the blue - Service Manual (1451KB)
The Zoom In icon ( + ) at the top, increases the view size; when you click on it..
The Zoom Out icon ( - ) decreases the view size.
Click on - Heatsink - in the right column.
HMMM, never mind!
Seems this particular PDF file is messed up. Or it's on my end. You may have better luck.
Instead scroll the page down until you come to - System Board,
OR;
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
1) Put your mouse cursor in the page number box, left-click once.
(Everything in page number box is now highlighted in blue)
Left-click.
Now Backspace any numbers out.
2) Type the page number you want.
3) Press the Enter key.
Go to Page 45
Additionally,
http://www.insidemylaptop.com/how-to-disassemble-dell-xps-15-l502x-laptop/
When you get to Step 27, you can access the cooling system, to remove it. (Replace Thermal Paste/Thermal Pad)
Regards,
joecoolvette
May 21, 2013 | Dell Xps 15 Laptop Computer (Intel Core i7...
Replace fan dell l502x
If you haven't attempted something like this before, I would suggest that you take it to a shop. If you want to have a go anyway, look on youtube for the same question.
Feb 23, 2013 | Dell XPS-L502X
M facing bios issue in my laptop??? can u fix it??
Not unless you tell us the problem you are having!
Nov 09, 2012 | Dell XPS-L502X
Dell xps L502x 2nd gen. i5.2520M (windows 7 HP) - "operating system not be found"
A brand computer like that will have a restore function this will reset all Operating System data and keep all the files in the DATA Partition of the hdd. So transfer all the files you want to keep and restart your computer and press the designated F key at the POST screen, you will find this in the manual.
Jan 29, 2012 | Computers & Internet
ASUS Z71V Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
