Question about Jenn-Air JEC9530 Electric Cooktop
I have jenn air electric cooktop and one of the stove is not heating. Please help
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
  • 883 Answers
SOURCE: jenn air electric cooktop
first, disable power to cooktop. next, replace either the mangled burner or the entire unit (after initial inspection leads to a logical prognosis)...sorry.
Posted on Nov 20, 2007
SOURCE: Jenn-Air electric stove top - burners/fan won't come on
I had the same problem. Went to an appliance store that carries Jenn Air. Replaced both plug in units. Now they work perfectly and it cost less than $350 total! Good Luck!
Posted on Dec 12, 2008
mgprice
  • 744 Answers
SOURCE: Gas Jenn Air Cooktop Issue with Electric Starter
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test. Hope this helps...Good Luck
Posted on Jun 26, 2009
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
I have a Jenn-air, C206-C model grill-range cooktop. Three of the 4 burners have stopped working. Any solutions?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Jun 04, 2010 | Jenn-Air JED8230 Electric Cooktop
The Grill side on my electric cooktop doesnt seem heat up enough
I had the same problem with the 45" Jenn Air downdraft cook top. The installation of the ductwork from the stove to the outside of the house was not properly installed. The stove is appr 18' from an outside wall and the flow of air was hampered by
too great a bend in the ductwork at the point below the stove on the underside of the house and the pipe going to the outside wall. I believe that was corrected with more curve in the vent work, making for a smoother flow of air. Make sense?
Jan 07, 2010 | Jenn-Air JED8230 Electric Cooktop
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring diagram
Hello
The wiring diagram is usually inside of the stove folded in a corner, or get the manual at the link I have provided and call them and they will email you one.
Check here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JEC9536&siteCd=JA_EN_US
Eddie Rentas
Tupper Lake NY
Aug 19, 2008 | Jenn-Air 35 in. JEC9536 Electric Cooktop
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JEC9530 Electric Cooktop Logo
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
