Question about Dishwashers
I have a maytag dishwasher #PDB3600AWX and it just isn't cleaning the dishes. Does it have a water filter that can be cleaned?
  • 40 Answers
It might be hard water deposits on your dishes. Go here to find out if you have hard water. http://www.citriclean.net/why-citriclean/
Posted on Dec 30, 2013
  • 677 Answers
SOURCE: HElp Dishes not coming clean
www.dishwasherfilter.com has a great new product out that filters the water going into your dishwasher. it reduces minerals that cause that white build up or residue. it goes under the sink and doesnt take up much room at all. my dishes looked terrible until i put this filter in. it is very affordable and works great.
Posted on Apr 03, 2008
  • 677 Answers
SOURCE: Dishes are not coming out fully clean
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
SOURCE: Dishwasher not cleaning dishes. Casade cleaner not disolved.???
KITCHEN AID DISHWASHER- SOAP REMAINS IN DISPENSER
Posted on Jun 29, 2008
SOURCE: DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Posted on Nov 15, 2009
  • 677 Answers
SOURCE: maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Posted on Mar 18, 2010
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
My Maytag dishwasher (MDB955AWS) will not drain ans is not cleaning the dishes properly.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back for any further assistance.
Daniel
Mar 19, 2011 | Maytag MDBH955AWS Stainless Steel 24 in....
I have a 5 year bosch shu43c05uc & my dishes aren't clean any more? i've cleaned the bottom lint container & it still isn''t clean? does my dishwasher need repair?
You should be able to get several more years out of it with a good maintenance call or a Do It Yourself routine on checking your water inlet valve. spray arms, internal filters.
Mar 08, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Hard film being left on pots & silverware
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes
Feb 16, 2011 | Maytag Dishwasher
Have a real problem with etching,filming spotting not cleaning properly.Dishwasher 18 months old.Have tried all solutions as per manual,no joy.
If you are in an hard water zone , then try reducing the amount of detergent used and then try cleaning the dishes.
Nov 11, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Dishes come out cloudy. do i need ro clean my may...
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
May 19, 2010 | Maytag MDB7100AWB Dishwasher
Maytag performa dishwasher PDBL390AWB - dirty dishes
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top Dishwashers Experts
