Question about GE JKP15 Electric Single Oven
How to turn of 1989 ge p7 buzzing clock - GE JKP15 Electric Single Oven
How can I check thermostste on GE P7 before buying new one
wow much to high to pay? it can be checked for continuity with an ohm meter. u can buy cheap meters for like 5 bucks or so. are u sure their trying to charge them much for a thermostat? maybe they thought u meant something else? if its getting way to hot u have a bad oven sensor? it to can be checked with a meter. When ur thermostat goes out due to overheating , the oven will not operate. thermal thermostats are not resettable. oven sensor is located near the back along the wall it thin and may have a glass look?
Feb 12, 2015 | GE Ovens
Manual ge p7
You should be able to access the clock from the back panel. Make sure the power is off and you can disconnect the power to the clock motor. Tape off the wire to prevent it shorting out against the case. generally the white wire is the neutral and can be safely disconnected without affecting the clock operation of the oven. Some clocks also control the oven operation. Make sure that you are not disconnecting this feature.
Nov 04, 2013 | Ovens
I have a 16 year old GE XL44 which has a manual turn clock that keeps buzzing. My husband stopped it, but it is going off again. The manuals I am finding on-line have electric clocks which we don't have....
Greetings,
Remove the power from the stove to prevent shock..remove rear access panal and locate clock....there will be a small motor attached to the clock..cut the wire going to the clock motor and tape....there are other ways, but this is easiest to explain..the clock will not be working after this...or, you can have your clock rebuilt or replaced with a current digital clock
Bruce Denton
Jan 04, 2011 | GE Ovens
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
May 17, 2010 | GE 30" Built-In Single Electric Wall Oven...
What year was the ge p7 wall oven manufactured? trying to find out the age of the oven.
I can go back to 1974-5 for mine, that's when my original Landlord bought the place and it still has the same GE P7 as when the complex was new...and it still works.
Oct 30, 2009 | GE Ovens
GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Jul 15, 2009 | GE JKP50SH Electric Double Oven
1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Feb 18, 2008 | Ovens
GE JKP15 Electric Single Oven Logo
26 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
