Question about 1999 Mercedes Benz C43 AMG Headlight Bulb Sylvania
Changing the bulb assembly
Details on removing the bulb assembly please.
    New Friend:
    Problem Solver:
  • 19 Answers
First try looking under the hood. The headlight assemblies access is usually behind the grille (under the hood).
If you can NOT see the wiring harness you may need to go to a dealer.
Look for the wiring going to the headlamp assembly. You may see a rubber cover (connection is under it) Try to pull the cover back and reveal the harness end socket, this can be pulled off.
the HARD part is getting the bulb holder (spring type wire) out to remove the halogen bulb. Usually there is ONE end hooked onto another 'Hook', it may be hard to see as well! This will SWING out, one side of the wire hook will stay in place DON'T PULL just move it to the side, like a Door.
PLEASE NOTE:
"DO NOT" hold the NEW Bulb with your fingers, use a tissue or plastic, the oil from human skin will cause the bulb to fail early - Breaking it
When you get the Old Bulb out place it in the old package to prevent breakage.
It is 'Possible' it could explode keep safe!
Posted on Nov 29, 2013
Changing low beam bulb
depending on which side it is either the battery box asembly or the air cleaner assembly has to be removed to get to the wire keeper that holds the headlight bulb assembly in the rear of the headlight housing. then release the wire keeper and the bulb assembly comes out of the rear of the headlight housing and you can change the bulb. do not touch the glass part of the new bulb assembly, only handle the metal part of the new bulb assembly.
Nov 10, 2013 | 2004 Mitsubishi Diamante
How do you change the front parking light bulb on a 2008 toyota tacoma
if you can not access or see the bulb under the hood in the corner at the fender or inside of fender you will have to remove the headlight assembly and all car makers are making changing bulbs a pain. if you do have to remove the headlight assembly then the steps per repair manual are to remove the grille,bumper cover,bumper filler.believe me there are a lot of customers that wonder why us technicians have to charge so much just to put a bulb in but we did not design the car and it is crazy what you see now days.........good luck and i hope this will help and if i can give any more details let me know......the bulb will twist to remove when you get to it.........let me know how you come out with the project.......
Jun 19, 2011 | 2008 Toyota Tacoma
Need help changing out the low beam on drivers side of 2006 buick rainier
Removal & Installation
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
  1. Turn the lamp switch to the off position.
  2. Make sure the bulb is cool before changing.
  3. Remove the headlamp assembly from the headlamp panel.
  4. Remove the rear access cover from the headlamp assembly.
  5. Disconnect the headlamp connector.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket
    counterclockwise.
To Install:
  1. Connect the headlamp connector.
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket
    clockwise.
  3. Install the rear access cover onto the headlamp assembly.
  4. Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
  1. Remove the grille from the front of the vehicle.
  2. Release the headlamp assembly retaining tabs.
  3. If equipped, disconnect the headlamp leveling motor connector.
  4. Disconnect the headlamp connector.
  5. Remove the park/turn and side marker bulb sockets from the headlamp
    assembly.
  6. Remove the headlamp assembly from the headlamp panel.
To Install:
  1. Place the headlamp assembly into the headlamp panel.
  2. Install the park/turn and side marker bulb sockets into the headlamp
    assembly.
  3. Connect the headlamp connector.
  4. If equipped, connect the headlamp leveling motor connector.
  5. Lock the headlamp assembly retaining tabs.
  6. Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
  1. Release the headlamp assembly retaining tabs.
  2. Disconnect the headlamp connector.
  3. Remove the park/turn bulb socket from the headlamp assembly.
  4. For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
  5. Remove the headlamp assembly from the headlamp panel.
To Install:
  2. For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
    socket into the headlamp assembly.
  3. Install the park/turn bulb socket into the headlamp assembly.
  4. Connect the headlamp connector.
Oct 28, 2010 | 2006 Buick Rainier
How to replace headlight bulb on 2002 chevy trailblazer
Headlamp Removal & Installation Bulb Replacement To Remove:
CAUTION
Halogen bulbs contain pressurized gas. Mishandling a bulb may result in the bulb shattering into flying glass fragments.
CAUTION
Make sure to wear eye protection when handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb, only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb properly.
CAUTION
Do not allow children to handle halogen bulbs.
  6. Remove the bulb from the headlamp assembly by rotating the bulb and socket counterclockwise.
To Install:
  2. Install the bulb into the headlamp assembly by rotating the bulb and socket clockwise.
Headlamp Assembly Chevrolet To Remove:
  5. Remove the park/turn and side marker bulb sockets from the headlamp assembly.
To Install:
  2. Install the park/turn and side marker bulb sockets into the headlamp assembly.
Jul 20, 2010 | 2002 Chevrolet TrailBlazer
Replacing headlight bulb ford focus
Most of this solution for changing a headlamp on a ford focus sedan is taken from solution 2's writeup, accept with a few more details that should help changing the bulb assembly for the novice. Pop the hood. At the front of the car, look to the back of the headlight assembly. There will be a plastic cover on the back. On some models, you need to unscrew the plastic cap; on others, it just pops or screws off. Remove the plastic cover and then take note of the orientation of the three prong connector on the back of the bulb assembly. This is important because the replacement bulb assembly is going to have to be positioned in the same manner. By noting the orientation before taking out the old assembly, it will be easier to orient the replacement bulb assembly after removal.
There is a small retaining clip that surrounds and holds the bulb in place. Removing the clip can be tricky. On my 2003 Ford Focus sedan, there is a special place to push and release the clip that is above the bulb - perhaps further above than you might think. Push the release clip and it will release the retaining clip from the bulb assembly. Gently pull the retaining clip down and out of the way of the bulb assembly. Pull the original bulb straight out. Remove the three prong connector from the bulb assembly. Connect the three prong connector to the replacement bulb and then orient the three prong connector as the original and push bulb assembly straight back into place. Jiggle the assembly slightly to seat it into the correct position in the headlamp housing and replace the retaining clip to hold the bulb in place. Replace the plastic cover on the back of the headlamp and replacement is complete.
No tools. 10 minutes.
Dec 16, 2009 | 2001 Ford Focus
Changing headlight on pontiac montana
Open the hood.
Remove the front turn signaVparking lamp
assembly
Pull the assembly away from the vehicle.
Unscrew the black retainer ring that holds the bulb
assembly in place.
Pull the bulb assembly straight up from the lamp
housinq
Unhook the electrical connector by lifting up the
blue tabs and pulling the bulb out.
Dec 04, 2009 | 2003 Pontiac Montana
How to replace the high beam bulb on a 98 GMC Suburban. What needs to be removed to get to it?
Headlamp Bulb: Service and Repair
REMOVAL PROCEDURE
1. Make sure the headlamp switch is in the OFF position.
CAUTION: Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments.
To help avoid personal injury:
- Turn off the lamp switch and allow the bulb to cool before changing the bulb. Leave the lamp switch off until the bulb change is
complete
- Always wear eye protection when changing a halogen bulb.
- Handle the bulb only by its base. Avoid touching the glass.
- Do not drop or scratch the bulb.
- Keep dirt and moisture off the bulb.
- Place the used bulb in the new bulb's carton and dispose of it properly.
- Keep halogen bulbs out of the reach of children
NOTE
: Avoid touching the bulb or letting the bulb come in contact with anything damp. Oil from your skin or moisture on the bulb can cause
the bulb to explode when the bulb is turned on. It either comes in contact with the bulb, clean the bulb with alcohol or a suitable degreaser and
wipe the bulb dry.
2. Remove the bulbs from the headlamp capsules by reaching from the engine compartment and by twisting the bulb counterclockwise.
3. Remove the 2 long screws from the top of the radiator support.
4. Pull forward the headlamp assembly (3).
5. Disconnect the electrical connector (2) from the burned out bulb assembly (1).
INSTALLATION PROCEDURE
IMPORTANT
- Replace a high beam bulb with another high beam bulb. The high beam bulb has a red gasket.
- Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a yellow gasket at the base.
1. Install the new bulb assembly (1) into the headlamp assembly (3).
Twist clockwise the bulb assembly.
2. Seat the bulb assembly with the connector facing down.
3. Connect the electrical connector (2) to the bulb assembly.
4. Install the headlamp assembly.
5. Install the 2 long screws through the top of the radiator support.
6. Tighten the screws.
Oct 30, 2009 | 1998 GMC Suburban
I have 2006 Grand Prix How do I change head lamp?
Caution Halogen bulbs contain gas under pressure. Handling a bulb improperly could cause it to shatter into flying glass fragments. To help avoid personal injury:
Leave the lamp switch OFF until the bulb change is complete. Always wear eye protection when changing a halogen bulb. Handle the bulb only by its base. Avoid touching the glass. Keep dirt and moisture off the bulb. Properly dispose of the used bulb. Keep halogen bulbs out of the reach of children.
Raise the hood.
Remove the headlamp assembly bolts from the upper fascia support.
Slide the headlamp assembly outward enough to release the headlamp bracket tabs from the slots in the upper fascia support.
Position the headlamp assembly away from the vehicle body to access the electrical connector.
Disconnect the electrical connector from the headlamp assembly.
Remove the headlamp assembly from the vehicle.
Disconnect the electrical connector from the headlamp bulb/socket.
Remove the headlamp bulb/socket retainer ring from the headlamp, by turning counterclockwise.
Remove the headlamp bulb/socket from the headlamp assembly.
Jun 13, 2009 | 2006 Pontiac Grand Prix
Ford focus 05 model changing dip headlamp bulb?
US Focus has one headlamp attachment that you have to raise car on hoist to remove it.
Headlamp Assembly Removal
  1. Remove the fender splash shield lower retaining screw.
    • Push the fender splash shield to one side.
  1. Remove the headlamp assembly lower retaining bolt.
  1. Remove the radiator grille.
  1. Remove the headlamp assembly.
    • Disconnect the headlamp assembly electrical connector.
Feb 25, 2009 | 2005 Ford Focus
Changing the headlights
This picture shows the rear side of the headlamp assembly. I've circled the access caps to the high & low beam bulbs (they just twist off (counter-clockwise) to access the bulbs. Depending on which engine is in your Tiburon, access is easier if you remove three 10mm mounting bolts to the headlamp assemblies and remove the entire headlamp assemblies (see illustration)
c173c7f.jpg You'll want to disconnect these two connectors .. then remember to reconnect them when you put the assemblies back on.
Hope this helps
Dec 20, 2008 | 2004 Hyundai Tiburon
1999 Mercedes Benz C43 AMG Headlight Bulb Sylvania Logo
50 people viewed this question
Top Sylvania Headlight Bulb Vehicle Parts & Accessories Experts
Darrell
JonSnell Electronic
JonSnell Electronic
Sam Rosario
Sam Rosario
Are you a Sylvania Headlight Bulb Vehicle Part and Accessory Expert? Answer questions, earn points and help others
