Question about Safety First Safety 1st Ultrasonic 360 Degree Humidifier
Safety 1st Soothing Mist Ultrasonic Humidifier will not power on. No light, no vibrations, no mist.
I have a Safety 1st Soothing Mist Ultrasonic Humidifer. I used it off and on for about a month with no problems. I attempted to turn it on recently and it appears to be receiving no power at all. The light will not even turn on. I opened up the bottom and I can't see any obvious issues (blown capacitors, disconnected wires, burn marks, rust, etc.) I already cleaned and dried the nebulizer and the water level sensor. Any thoughts?
I am unable to open the tank cap.. it is stuck.
Service and Support at HolmesProducts com
HolmesĀ® Brand Customer Service
HolmesĀ® Home Appliances
1-800-546-5637
Phone Number
800-284-3267
Holmes Calls You Instead Home > Find a Call-back > Holmes Calls You Instead
It's true! We can have Holmes call you so you don't have to wait on hold - free! You can go back to what you were doing, and avoid the waiting on hold on the phone. We'll do the waiting for you.
reference: http://gethuman.com/phone-number/Holmes/
Nov 23, 2014 | Jarden HWM6008-UM - Holmes Warm Mist...
How do you take apart a Vicks 3700 humidifier and clean the fan?
Hello Judith,
Here is a Youtube video that should help you clean your humidifier.
If not exactly search through Youtube for more specific details. You may find many helpful videos with proper search, but be sure to watch video completely to be sure it is the task you are trying to accomplish.
PEACE
Kaz com How to clean warm mist humidifier
May 25, 2014 | Vicks V3700 Starry Night Cool Mist...
The Humidifer will not reach desired humidity level
most I see have a dipole motor with an atomiser wheel on it..this takes the water and makes a mist out of it..your issue may be that the motor bearings are dry and need wd 40..the disc should turn freely if its stiff the blower will not turn.. needs oiled up..
Jan 24, 2014 | Essick Air Essick Pedestal L Humidifier -...
Relay turns on but no water coming out to the pad. Water supply line working ok ]
Does the water valve cyilinoid valve get power and if so does it make a magnetic pull against a screwdriver. If not check to see if the windings are open with a ohm meter when the power is off. if has magnetic pull it may just be a clogged screen filter in the water inlet. I would check that first.
Oct 16, 2013 | GeneralAire 1137 Legacy Series Power...
My honeywell air purifier is emmiting an awful
Mine quit too... The led screen went blank so I changed the battery. Now it does nothing. I totally disassembled it as the fan was turning stiffly.(should spin very easilly) The grease in the end bearing was stiff. I washed the gummy grease off the shaft and reoiled with synthetic oil. Your smell is probably motor windings overheating. I disassembled the electronic control and was disgusted to see that there is a glass fuse soldered to the circuit board. I believe the only reason for this fuse is to cause us consumers to needlessly replace otherwise good equipment. (It cost more to pay a repairman to replace the hidden fuse than to purchase a new unit)The fuse is not blown. At least this fuse actually looks lide a fuse unlife the stealth fuses most electronics have hidden in them. I can not obtain a wireing diagram on my 17005 unit but it has a black box inside behind the control panel. It looks like a small start capacitor, but it has a temp rating on it of 70*C. I suspicion it is a single use over heat safety which triggered when my motor got hot due to stiff bearings. I refuse to play their game and purchase a new air cleaner. I love this one... So, if I can not determine what that little black box is, I am going to bypass all the crappy electronics and just drill a hole on top by the handle and install a hi/lo/off manual switch directly to the motors wire hasness. This machine will never give me problems ever again, and if I oil the motor every couple of years with synthetic (Ander oil) this unit WILL last me for the rest of my life...
Oct 26, 2009 | Honeywell 17000 Air Purifier
Ionic Breeze - Black Quadra won't stop hissing
I have the same problem. The one thing that I DID notice is that it seems to occur more often in winter. Thus, I attributed it to dryer air conditions--too much static electricity being the culprit. With the unit off, I sprayed a fine mist of water into the housing and that cured it for a (albeit-short) time. Best solution would be to increase the humidity via a humidifier...
Jan 30, 2009 | Air Purifiers
Safety First Safety 1st Ultrasonic 360 Degree Humidifier Logo
Top Safety First Air Purifiers Experts
Are you a Safety First Air Purifier Expert? Answer questions, earn points and help others
