Question about Whirlpool Freezers
I need to change a thermostat freezers WVG25 - Whirlpool Freezers
Can a traulsen commercial fridge be changed to a freezer by changing out a thermostat or a set point somewhere?
probably not. you would need to change the expansion device. You could probably get as low as 15-20 degrees but I doubt you could do much more than that without some system changes.
May 20, 2017 | Traulsen Freezers
Change defrost thermostat on model dff9102w
Danby, has recall on defrost timer . please try that on ,if still you like to change defrost thermostat open the back cover in freezer you can seeit
Nov 07, 2014 | Danby DFF9102W Mid-Size Refrigerator White
29502 freezer
No other way to make changes. Issue is more then likely the thermostat that needs to be changed. Basically it's thinking your freezer is warmer then it actually is
May 19, 2014 | Kenmore Freezers
How can i change a delfield 407-dhl from a freezer into a cooler
Refrigerators and freezers are almost identical except for more controls on a freezer. Just raise the thermostat to the temperature you need. If it won't adjust that high, you will need to replace it.
Dec 02, 2013 | Freezers
Freezer is icing up too much
dear sir,
need to change your defrost setting in your freezer if its alredy good then check thermostat device i think it is not working cause of that compressor is running continue ,
please contect to your service technician for replace the thermostat unit or temreture sensor(if any).
hope answer the question
thank you
please vote!
Jul 02, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
Changed thermostat worked 4/5 days and defrosts again
take back of freezer out does the coil have a full frost pattern? make sure the bulb to the t stat is where it needs to be and make sure they didnt give you the wrong one it might be a frig stat
May 26, 2010 | Freezers
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Freezers Logo
16 people viewed this question
Top Whirlpool Freezers Experts
christian nielsen
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
