Question about Kenmore Elite HE4 Electric Dryer
Dryer I recently moved and have a Kenmore washer and Dryer, the problem is i have to indoor vent!!!! How do i vent? can i use a nylon like suggested?
  • 5,911 Answers
There is actually an indoor vent kit that consists of a dryer hose and a lint bucket that you place water in. The hose attaches to the dryer and connects to a lint bucket that holds a small amount of water. The concept is that the vent blows air straight down into the bucket and any lint gets trapped in the water. On the negative side, you will have to empty the bucket from time to time and keep it in a location where it is not going to get tipped over. You also need to make sure the dryer hose does not get kinked or pinched off in a way that prevents air flow, or your dryer will begin to back up with lint, which could cause dryer failure and/or a fire. Is there any reason why you can't vent to the outdoors? The reason I ask is because running a dryer in this fashion can cause humidity build up and mildew in your home over a long periods of time. Nylon will also tend to collect lint and clog. You will have to be diligent about keeping it cleaned. I hope this helps you. You can purchase an indoor vent kit at most appliance stores.
Posted on Oct 10, 2007
SOURCE:
Indoor dryer vent box issues
have you put some water in the lint box. you need to change the water after every use as well
Apr 18, 2014 | Sears ProFlex Indoor Dryer Vent Kit
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
Kenmore Dryer 70 series. Recently moved. Clothes take 3 cycles to dry when vented to wall vent. Woreks fine when vented to room.
Your wall vent is restricting your air flow somehow. Many times they get plugged with lint. When this happens it activates a thermal safety switch in the dryer and doesn't let it heat to the proper level.
Jul 03, 2010 | Dryers
Dryer not getting as warm as it used to. We recently moved into a new home and this problem has started since we moved. Kenmore EcoCare dryer is about 8 years old.
check to see if the dryer vent is clear (the pipe that runs to the outside of the house). this vent might be ristricting the air flow more than the one at the place you moved from
Mar 10, 2010 | Dryers
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Moving a large washing dryer to access vent behind
Call a friend.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 11, 2009 | Kenmore Elite 45986 Front Load Washer
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Replacement Cost Information For Damaged Washer & Dryer
if they were kenmore then more than likely they were built by whirlpool look at whirlpool for copariable models by going to lowes .com you can find same looking models but with the whirlpool name
Jan 20, 2008 | Washing Machines
Gas smell from dryer
your igniter needs to be replaced.
Jan 26, 2007 | Kenmore 74842 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
236 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
