Question about Globe Union Glacier Bay 8 In Double Handle Kitchen Faucet with Spray in Chrome F80246
Replace ceramic disk cartridge
How do I replace the cartridge? Do I remove the handle or do I have to remove the entire faucet?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
First shut off water to the faucet. Most faucets have a screw on each hot and cold handle, remove the screw, then remove the handle. Now you should see a large Nut around the faucet stem, remove the nut, then the stem can be removed. Depending on the faucet you have, the ceramic disk can be replaced. Most faucet companies give a lifetime warranty on the disk, so you can order a new one for free if you have the warranty papers of the faucet, if not, you can usually get new parts on line, or at a plumbing store.
Posted on Dec 29, 2013
Elkay kitchen faucet model lk7124 replace stem
ELKAY ' Strainers, Fittings + Other Accessories for the Home
www.elkay.com/strainers-fittings-other
Results 1 - 15 of 91 - CERAMIC LONG STEM SQ MNTG COLD. 45921C. Brass. Price pending ... CERAMIC SHORT STEM SQ MNTG HOT. 45924C. Brass.
ELKAY ' Stainless Steel Kitchen Sinks, Faucets, Cabinets ...
www.elkay.com/
Elkay is an American-owned and operated innovative manufacturer of stainless steelkitchen sinks, faucets, foodservice products, cabinets, drinking fountains ...
[PDF]SPECIFICATIONS
aitcheson-dc.com/files/2012/07/EL.LK2432.pdf
LK2433 Dual handle, concealed mount mixing faucet. Metal ... (101.6mm). ModelLK2433 ... Hi-ArcĀ® Dual Handle Kitchen Faucets. Models ... Elkay warrants to the original consumer purchaser that the Elkay faucet pur- ... replacement parts (or if no longer available a comparable product) if the faucet ... METAL STEM.
Amazon.com: Elkay - Faucet Parts / Rough Plumbing: Tools ...
www.amazon.com > ... > Faucet Parts
Amazon.com, Inc.Results 1 - 24 of 921 - Elkay GOBG1118SS Dayton Kitchen Sink. by Elkay. $44.50 ...Elkay A51947R Replacement Diacore Cartridge with Brown Stem. by Elkay.
Elkay A51947R Replacement Diacore Cartridge with Brown ...
www.amazon.com/Elkay...Replacement.../B0033UX8...
Amazon.com, Inc
Jan 14, 2016 | Elkay Plumbing
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
So I got a single handle inexpensive faucet that came with the sink. I was not expecting top quality but I was expecting it work without chugging for awhile. Do they have bad cartridges right out of the...
Yes, it's possible for almost any product to be bad straight out of the box.
Either remove the faucet and return it for an exchange or replace the ceramic cartridge.
Jun 20, 2011 | American Standard 4205.001.021 Reliant+...
Dripping facet
If a faucet is leaking the necessary repair will be either:
1. For a ceramic or washerless faucet, replace the cartridge.
2. For a typical old fashioned faucet, open the faucet, replace the washer (and packing if it has any) and verify that the faucet seat has not eroded.
The newer washerless faucets cannot be repaired except by replacing the cartridge. Cartridges for most common faucets are available at most home improvement stores or plumbing supply houses.
It sounds a lot more difficult than it really is, just shut off the water (usually a shut off valve under the sink). After the water is off, remove the handle and any chrome protective covering. Depending on the faucet type, it may be a little difficult to remove the cartridge since they are often covered with mineral build-up or corroded into place.
Once you remove the old cartridge the new one usually goes into place easily.
NOTE!!!
For single handle faucets, make sure you put it in the right way, some of them will put the hot to the wrong side if you put them together backward.
Mar 13, 2011 | Home
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 | Plumbing
Price pfister sb o34-4nss leaks
Well, this is generic for fixing a Price Pfister ceramic disc valve labatory faucet. On the top of the handle, there is usually a screw cover. Pry it off. Then insert a phillips screwdriver or allen wrench, depending on model and remove. Then remove the handle. At this time, make sure the water is shut off to the faucet. You'll need a socket or wrench to remove the cartridge. On many, the size is 3/4. Loosen all the way, then pull out the cartridge and replace. They are usually between 10-30$/cartridge. Insert new cartridge, tighten (but dont overtighten or you will kill the gasket), then replace the handle and turn on water. Check for leaks.
Nov 23, 2008 | Plumbing
Globe Union Glacier Bay 8 In Double Handle Kitchen Faucet with Spray in Chrome F80246 Logo
200 people viewed this question
Top Globe Union Plumbing Experts
mike simpson
Tom Chichester
Don Tiff
Don Tiff
Level 1 Expert
Are you a Globe Union Plumbing Expert? Answer questions, earn points and help others
