Question about Frigidaire FEQ1442ES Electric Dryer
Front load frigidaire dryer does not heat and runs for a few minutes then shuts off and all the light flick off and on
    Top Expert:
  • Frigidaire Master
  • 12,962 Answers
Checkout the heating element. If it is open the electronics of machine may be programmed to turn it off and blink lights.
Posted on Nov 23, 2013
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 7 Answers
SOURCE: dryer beeps when it isn't running
sounds like the control board, is there any codes displayed?
Posted on Oct 16, 2008
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
We have a frigidaire infiniti dryer AEQ6500CFGO it runs for about ten minutes an shuts off, lights on right hand side blinking and no heat! Ive replaced main board and same problem? Help plz! :)
Check the airflow, one way to do this is unhook the dryer from the ductwork and let it run with a wet load of clothes to see if it stops. If it does not then the issue is lack of airflow because of the ductwork. If it does stop then the issue is because of overheating somewhere else.
Jun 28, 2015 | Frigidaire Dryers
Frigidaire LEQ1442ES1 will run only a few minutes. Heats up runs aprox 3-4 minutes then shuts off, starts beeping and lights on the right side of the panel blink rapidly. Pushing cancel stops it and y
Good Morning friend, thank you for your post!
From my understanding your Frigidaire dryer, LEQ1442ES1, will run and then shut down after three or four minutes. I would recommend a reset on your dryer which you can do by unplugging your power cord for roughly ten minutes.
If that does not correct the issue it sounds like a potential problem with your control panel or a sensor. I would suggest having a professional come out and repair your appliance to avoid any unnecessary part purchases. -Matt
Oct 10, 2014 | Frigidaire Dryers
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
Dryer will run but will not heat and the lights all flash
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# GLEQ2152ES, will run for a few minutes and then stop and display "AD" with the lights flashing. The "AD" means that your appliance was in an automatic dry mode. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Dryer wont heat up
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDAIRE MODEL FEQ1442ES1 LIGHTS FLASH THEN DRYER SHUTS OFF
Hi - From what you have described the unit could possibly have a communication problem with the control board. However, if the unit is producing heat but will not complete cycle please confirmed that the door is closing properly. If it is not, the unit could possibly have a defective door switch or cord/wiring. Either, or, could be faulty at this time. I would suggest contacting a professional to move forward accurately since this is not a typical DIY job.
Oct 13, 2012 | Frigidaire FEQ1442ES Electric Dryer
I have a Frigidaire front loaded dryer that is just a few years old. It continually beeps and the lights on the front panel flash and after few minutes it shuts off. How do I fix this problem?
I had encountered issues like your concern regarding the problem Frigidaire dryer. Most of them had contacted the Frigidaire repairman to check and put in a new control board and it works like brand new. Though it costs $100 for the service but this amount will be refunded if you contact the Electrolux and ask for a code to give unto the repairman to cover the cost of the board.
You may contact also:
Chris Polk
Escalation Specialist
Electrolux Major Appliances
chris.polk@electrolux.com
So you may be guided, just send your contact information, and the best time to contact you. He would also need your model and serial number and a file number if available.
I hope it helps ^_^
Aug 26, 2012 | Frigidaire Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
213 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
