Question about Gigabyte GA-K8U-939 (MOTGB08) Motherboard
Memory installation I bought 2 sticks of identical 1GB memory. If I install one the computer boots fine. When I install both all I get is a series of long beeps. I made sure both were in the same color sockets but the same result. Not sure which slot is really is the DDR1. Thanks for any help.
  • 47 Answers
Perhaps there is a problem with the 2nd slot in your motherboard.
Tr this - place the two memory sticks in the Outside two slots - the orange ones.
OR you didn't get the correct speed memory - usually the motherboard will interleave two slots to access the memory faster - than if only one memory module is installed.
The "DDR1" slot is the one closest to the CPU processor chip.
The manual for your mb can be found at: http://download.gigabyte.us/FileList/Manual/motherboard_manual_k8u939_e.pdf
Posted on Nov 24, 2013
Testimonial: "Unfortunately that didn't work either but I put one in DDR1 and one in DDR3 and that worked."
SOURCE: Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Posted on Jan 09, 2008
  • 12 Answers
SOURCE: not booting, i mean even getting past post.
how many beeps..3 long beeps means no memory signal, 3 short beeps and 1 long beep means some pci cards is damage or not working properly.
Posted on Feb 05, 2008
yboyandrei
  • 828 Answers
SOURCE: Too much memory for Giga-Byte K8M800-8237
The issue of this is not too much capacity on your memory., i tell you the problem is incompatible both of them. Check again your memory and what brand are there.
Because something motherboard settings are being notify if reliable to you to use different kind of RAM you have. Read the motherboard manual to find out some settings to enable both of them are not the same brand or model.
Posted on Aug 03, 2009
xptareq2000
  • 1447 Answers
SOURCE: GA-770TA-UD3 memory configuration error. I
You can use only 2 pcs Ram not 3 pics because you not mantain channel
Posted on Mar 17, 2010
StuartB
  • 807 Answers
SOURCE: HI I have a Gigabyte motherboard 945GCMX-S2, I have a 1GB ddr2 (667 Hz) hynix ram already installed ..to upgrade it i installed another 1GB dynet ram (666 Hz)..but my cpu beeps now...i remember runni
You should be able to as it can take 4 gig total according to the manual.
Memory:
2 DDRII DIMM memory slots (supports up to 4 GB memory) (Note 2)
Supports dual channel DDRII 667/533 unbuffered DIMMs (Note 3)
Supports 1.8V DDRII DIMMs
Note 2. Only for GA-945GCMX-S2.
Note 3. Only for GA-945GCM-S2.
Posted on Feb 06, 2012
DC7600C memory
As the HP DC7600C it is an older computer, it seems to have a maximum of 3 GB RAM memory. You can mix module sizes, eg a 2MB + 1MB
Jan 31, 2014 | HP dc7600 PC Desktop
I put in two sticks of 1gb pc2-4200 533mhz and the computer started, began to load, then stoppped. i shut the computer off, turned it back on and nothin. i removed the second chip and replaced it with the...
You have not mentioned the manufacturer and the model of the PC. The general answer for this question will be :-
1. to check the maximum memory capacity of the PC
2. In some PC's you have to use 2 identical memory sticks otherwise it would not work.
If not this 2 then 1gb memory stick is bad.
Please re-post this with the manufacturer and the model of the PC so that we can assist you in a better way.
Was this helpfull ?
Please rate this.
Mar 16, 2011 | Computers & Internet
Installed 2 GB of Ram (both 3200 1 GB chips). PC would not boot coorectly with 2 GB installed (errors galore). However PC runs fine with only one 1GB installed. Running XP ?
Both ram sticks must be identical to work together. A different manufacturer of one can cause all kinds of problems. Did you go to 'setup' to make sure the machine recognized the second stick? The cure is likely to be purchasing another stick identical to the other new stick. Hope this helps!
Dec 27, 2010 | HP Pavilion a450n PC Desktop
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
My computer does not work with two 2GB RAMs
I think, one, out of the two is defected. Make pair with other memory or try changing the slots and vice versa. And for dual channel memory mode, you must installed two identical memory. I mean sizes and makes may different, but bandwidth should be identical to each other.
Jul 30, 2010 | Intel DG31PR Motherboard
I bought the proper matching two 1Gig sticks of memory to upgrade my 2G mHz TC4200. I installed them and it wouldn't boot, so I swapped back the 1G stick to the original 512mHz chip and it booted. Then I...
Ok, Rob, did you buy the memory from Compaq/HP? Or is it a 3rd party set (ie. Viking, PNY, etc.)? Sometimes, Compaq/HP computers are VERY picky about the specifications of the memory that the mother boards will use.
If you bought them from a 3rd party vendor, I would recommend taking them back and exchanging them for another brand or even just another set of sticks, but, before we go that route, let's try something else.
Install a 1gb stick and the 512Mb stick and then go into the BIOS and see how much ram is being registered there. If it reads all 1.5Gb of ram, then we know it is something else, if not, then we have somewhere else to look.
Assuming the BIOS registered the full amount of ram, try removing the 512Mb stick and then boot the computer, enter the BIOS and see if it is reading the 1gb stick properly. Assuming it did register the 1gb properly, swap the 2 1gb sticks out and repeat. If it did NOT register the lone 1gb stick, try moving the 1 gb stick to the other socket, and checking the BIOS again. If that works, then swap the 1gb sticks out, repeat the BIOS check.
Assuming that after you swap out the 2 sticks and they both work as lone sticks, go back into the BIOS and look for an advanced page or an option to turn on a "Diagnostic Mode" or "Memory Test", and run the memory test on each stick- one sitck at a time, to see if there is a minor/major memory addressing issue, with either stick.
If they both pass individually, then, try reinstalling them both together and check to see if you can reach the BIOS with them both in place. If not try putting the 512 in the 0 or first memory slot and the 1gb in the second slot, then repeat the memory test, swap the 1gb sticks again, and repeat the memory test on the second stick- (the thinking here is that if it is not the memory sticks themselves, perhaps it is the motherboard or one of the sockets for the ram that is bad).
If you can reach the BIOS with both 1gb sticks in place, but, not actually boot to the operating system, then it is possibly a timing issue- this SHOULD BE AUTOMATICALLY configured, but, if you are an overclocker or a "performance wonk" you may have changed a relevant setting in the bios that controls the speed at which the memory and the processor interact. Or it could be a problem with windows hardware monitor not accepting the changes to the amount of memory in the machine. To test this possibility try going into "safe mode" at boot up, after the BIOS screen/Compaq logo has come and gone.
If you can boot into safe mode and not into regular mode, it is a problem with something in windows. Sometimes, just booting into safe mode alone will fix it, sometimes, it is necessary to run the restore DVD on the computer to fix the problem windows is having/ or alternatively reinstall windows without running the restore DVD, using this method will usually fix windows, with out deleting all of your data. You might have to reinstall a few programs afterward, but, your pictures, mp3s, document files, etc. will still be on the drive. Running the restore DVD almost always deletes your data, so USE THAT SOLUTION AS A VERY LAST RESORT, ONLY AFTER YOU HAVE TRIED EVERY other option I have given you.
Good luck, and hope this helps.
Sep 02, 2009 | Compaq tc4200 Tablet PC
Cant install full 2GB of memory in my emachines t3990
try removing the cmos battery and put it again and booting up.. since you have bought same kind of ram i dont think it could be a problem.also check for the jumpers in *********** board where you can reset your bios. be sure to read *********** boards manual before this
Feb 10, 2009 | E-Machines T3990 (RBT3990) PC Desktop
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Memory Stick Installation
So it seems you got the DDR / DDR2 side of the equation correct, but unknown to most, there is 'low' and 'high' density memory.
The density of memory refers to the number of chips used to make the total amount of memory that your memory stick contains. e.g. High density memory has few, large capacity chips to make up the 1024MB of memory on the stick, whereas low density memory uses many, small capacity chips to make up the same 1024MB total on the stick.
Typically, if it is a low / high density conflict, it is the 'low density' sticks only that will boot.
Me, I purchase Kingston memory when I'm unsure what the motherboard will be, and it has never failed to work.
I fix computers.
May 19, 2008 | EliteGroup PM800M2 Motherboard
Gigabyte GA-K8U-939 (MOTGB08) Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
