Question about Kitchen Appliances - Others
I have a frymaster computer magic 111 it says cycle hi lo pro hoe help
I ave a frymaster computer magic 111 i changed the oil in it and put new in and itsays cycle hi lo pro hoe help i puta new thermalcouple in it and it still says the same i also put the code in it and it still says the same thing can u help me please
Frymaster pump and motor
Hi there.
Filter paper may be clogged causing the pump motor to trip-off after the filtration of the second fryer, better scrape off any filtered debris on paper afrte filtering.
Also oil temperature must be at least 250F or above to lessen the load on pump motor as oil with low temperature is thicker than oil with high temperature.
Regards.
Apr 12, 2012 | Frymaster Dean Kitchen Appliances - Others
How do u program a new button for time? We have been introduced a new item that only needs to cook for 1 min & 30 seconds & were not sure how to do this. Model # SCFD350GNCS Serial # 0904TS0005
It will depend on which computer configuration you have on your fryers.
You can download this manual from frymaster to help, it contains all programming instructions, just find the computer/controller you have and follow the steps.
Computers Operation Manual from Frymaster.com
Jun 08, 2011 | Frymaster Dean Frymaster/Dean FPEL3 Deep...
Can someone tell me where to bring my 2007 yamaha vstar custom for a tuneup and oil change just got the bike and need a good check up i live farmingville ny 11738 area thank you timi
Black Jack Cycles Inc, 835 S 1st St, Ronkonkoma, NY 11779
(631) 467-3122
Andiamo Scooters, 1585 Lakeland Ave, Bohemia, NY 11716
(631) 567-8585
Island Iron Motorcycles, 2554 Middle Country Rd, Centereach, NY 11720
(631) 981-8370
Crime Syndicate, 1075 Portion Rd # 16, Farmingville, NY 11738
(631) 698-3818
Your Motorcycle Shop Inc, 1330 Lincoln Ave # 1, Holbrook, NY 11741
(631) 285-7940
Supermoto Italia, 815 Middle Country Rd, St James, NY 11780
(631) 584-4340
Replicycle Sport Bikes, 80 Knickerbocker Ave # 6, Bohemia, NY 11716
(631) 567-2022
Harley-Davidson Inc, 4020 Sunrise Hwy, Oakdale, NY 11769
(631) 244-9000
Fun Wheels Ltd, 2297 Route 112, Medford, NY 11763
(631) 289-9242
East End Motorcycle Works, 476 E Main St, Patchogue, NY 11772
(631) 289-3300
Long Island Cycle & Marine, 1660 Sunrise Hwy, Bay Shore, NY 11706
(631) 666-4666
www.longislandcycle.com
Port Jefferson Motorcycle Str, 106 W Broadway, Port Jefferson, NY 11777
(631) 476-0722
Ryde Motorcycles, 106 W Broadway, Port Jefferson, NY 11777
(631) 385-0229
North Shore Cycle & Marine Inc, 6160 Jericho Tpke, Commack, NY 11725
(631) 858-2300
Formula One Motorsports Inc, 193 W Main St, Bay Shore, NY 11706
(631) 969-9480
Midnight Oil Motorcycles, 333 Route 25a, Rocky Point, NY 11778
(631) 744-6678
Perry Michael Designs, 1 Kendrick Ln, Dix Hills, NY 11746
(631) 427-6900
East End Motorsports, 895 Montauk Hwy, Shirley, NY 11967
(631) 399-7390
Carl's Cars, 670 Sunrise Hwy, West Babylon, NY 11704
(631) 661-0177
East Coast Super Bikes Inc, 525 Sunrise Hwy, West Babylon, NY 11704
(631) 661-5670
Jet Sport Enterprises Inc, 390 Jericho Tpke, Huntington Station, NY 11746
(631) 427-4400
Confidential Motorcycles, 630 New York Ave, Huntington, NY 11743
(631) 935-1464
Bmw Ny Motorcycles, 508 New York Ave, Huntington, NY 11743
(631) 427-4045
www.bmwnyc.net
Long Island Scooters, 297 Sunrise Hwy, Lindenhurst, NY 11757
(631) 884-8401
Long Island Kawasaki-Yamaha, 67 N Broadway, Hicksville, NY 11801
(516) 935-6969
V-Twins Cycle Shop, 27 Hamilton Ave, Oyster Bay, NY 11771
(516) 922-5059
Champion Honda, 544 W Old Country Rd, Hicksville, NY 11801
(516) 433-0701
Honda Of Riverhead, 1407 Pulaski St, Riverhead, NY 11901
(631) 727-5510
www.hondaofriverhead.com
Eastern Harley-Davidson, 1570 Old Country Rd, Riverhead, NY 11901
(631) 727-4700
Maximum Motorsports, 1133 Old Country Rd, Riverhead, NY 11901
(631) 727-5988
www.maxmotors.com
Apr 19, 2011 | 2007 Yamaha V Star Custom
My frymaster just got boiled out. And when we put in the new oil and turned it back on the display said "O-HI" on the left side and "problem" on the right side. What could cause this...
http://www.partstown.com/frymaster/parts#search-tab-content=manuals-and-diagrams
without model number, I can only talk generically. This sounds like the high limit is open and needs to be reset. The partstown website I attached should take you to where you can find your manual and this should help you fix it.
Sep 24, 2017 | Frymaster Dean H17-SC Deep Fryer
My power supply went down, i put a new one in but it is a 20 pin the gigabyte is 24 pin,it fits but will not work, have i got to use a 24pin,i was told a 20 will work,i hoe u can help
Hi davids38,
I really recommend getting a 24-pin adapter Power Supply Unit (PSU). I had this problem once and did purchase a 24-pin adapter for my 20-pin PSU but my computer wasn't stable (random reboots and lock up). I purchased a 24-pin PSU and my computer worked fine ever since. Hope this helps.
Thanks
Feb 22, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
I have a frymaster gf14sd and when turned on for about 20 minutes the fryer turns off and pilot light goes out and will not restart til it cools down .
First you will need to determine what the oil temperature actually is when the fryer shuts down. The reason for the shutdown is likely the hi-limit thermostat is tripping. That could be the result of the hi-limit thermostat being faulty or the thermostat is faulty and the oil is actually too hot eg: 450F. Once this is determined, either the thermostat or the hi-limit will need to be changed. The part number for the thermostat is 807-1692 and the hi-limit is 826-1177. I know this post is late, hopefully it will help someone.
Aug 20, 2010 | Frymaster Dean 1824G Deep Fryer
Can you please help me about change theoli
In std form I suggest to change oil every 10.000 km (6750 miless) with a new oil filter on alternate cycle
Mar 21, 2010 | Yamaha 1900 XV 1900 A Midnight Star
Hi may magic arm wont tighten,
Send it to Bogen for repair.
Bogen Imaging Company
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Oct 01, 2009 | Cameras
Kitchen Appliances - Others Logo
23 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
