Question about Pinnacle Studio 14 HD
Activation keys won't work
After entering activation keys, response - cannot open pixie file...
Anyone have a working windows xp home sp3 product activation key? Mine has exceeded its limit
Re activate
Microsoft Windows requires an activate code when you install the operating system. This product key is evaluated each time the system is booted or when you decide to update the operating system critical files. If you installed an incorrect key or your machine's hardware changed significantly, the operating system prompts you for a valid key. If your product key has expired, you can contact Microsoft to purchase a new one. Enter a new key in the system settings in Windows to enable the operating system and continue using the machine.
Click the Windows Start button, then select "Computer." This opens your computer properties window. Click the toolbar item labeled "System properties." In the Window that opens, click "Click here to activate Windows now" and click the "Continue" button. This opens a dialog window with a product key text box. Enter your valid Windows product key and press the "Ok" button. Reboot the machine for the changes to take effect. The next time you boot, the operating system is activated and the error message no longer displays. Hope this helps.
http://www.microsoft.com/licensing/existing-customers/activation-centers.aspx
Jan 05, 2013 | Computers & Internet
How can i activate gprs settings in palm pixi mobile
how can i activate gprs setting in palm pixi mobile
Feb 08, 2012 | Palm Pixi Plus Cell Phone
I CANT WORK AT MY MS WORD BECAUSE THE 2007 MICROSOFT OFFICE SYSTEM WANTS TO ENTER THE PRUDOCT KEY. HOWEVER, IM TRYING TO ENTER THE 25 COMBINATION OF LETTERS AND NUMBERS INDICATED IN STICKER OF MY LAPTOP,...
The sticker on your laptop case is the product key for the copy of Windows installed, not for Microsoft Office. That key won't work on Office since it's for a different product.
Many computers come preloaded with a version of Office that lets you use it for a limited time,but then you need to purchase a key to activate it if you want to keep it. If you don't want to spend money on the Office product, download and install OpenOffice instead.
OpenOffice is a completely free alternative to Microsoft's Office suite. It has all the same tools (word processing, spreadsheet, database, presentation, etc.) as Office. It can also work with a number of different file formats including Office types like docx. Files created with OO can be opened by users of MS Office since they are compatible.
If you absolutely need MS Office (because of some particular feature, for example), you'll need to follow the links in the program to purchase a key from Microsoft. Otherwise, switch to OpenOffice and save the money.
Apr 18, 2011 | Microsoft Office Computers & Internet
My msoffice 2010 do not activated properly
Did you enter your key and activate (e.g. did you do the steps outlined in this page)
http://www.microsoft.com/office/2010/en/activation.aspx
If you have followed the steps and did not work please try the following. Go to File tab \' Help and click on the Change Product Key link.
Enter the key on the page corresponding to your product (e.g. if you\'re running Word, enter the Professional Plus key, since Word is part of the Professional Plus suite).
Click Install to install the key. Then restart Word, and you should be prompted to activate.
Continue with activation, and restart Word again. If you click File tab \' Help, you should see "Product Activated" on the right hand side.
Mar 14, 2011 | Microsoft Office Professional 2007 Full...
My first problem: I have a Verizon Samsung Alias 2, which is having problems. Solution to first problem: I bought a new non-contract Verizon Palm Pixi Plus to replace the Alias 2. Second problem:...
No, you cannot unlock the Palm Pixi Plus and put it on a plan that is not compatible with a smartphone. If you want to continue to use Verizon service, you will have to purchase a phone that is compatible with your current plan, or change to a different plan that will work with your Pixi Plus.
Jan 20, 2011 | Palm Pixi Plus Cell Phone
I WANT TO INSTALL TALLY 9 AND USE IT WITH OUT INTERNET CONNECTION WILL IT BE POSSIBLE. HELP
To activate your license offline follow the steps shown: Go to Gateway of Tally ???? Press F12: Configure > Licensing > Offline > Activate The Activation Form appears ???? Enter the Serial Number in Serial field ???? Enter the Activation Key in Key field ???? Enter the Email ID in E-Mail field ???? Tally displays a message indicating that the tally_req.lic file has been successfully generated. ???? Copy tally_req.lic file available in the Tally folder to a floppy/CD ???? Paste tally_req.lic file to another computer with Internet connectivity and Tally installed. ???? Start Tally ???? Press F12: Configure > Licensing > Offline ???? Select Send External Request to send the request file to Tally Licensing Servers. The response file called tally_resp.lic is generated and saved in in the Tally folder. ???? Copy the tally_resp.lic file to a floppy or CD and paste the file into the Tally folder where the license has to be activated. ???? Start Tally ???? The Register Now screen appears, ???? Press Enter to work on Tallly
important:if this information was helpfull to you please vote for me and write a comment for me.
Sep 02, 2010 | Computers & Internet
What is product key while entering using word and what i can type for product key
Microsoft Office Product Activation issue Work around
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
1. In Windows Explorer, brose to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
2. Right click on Proof.XML file, select "Open With…" in the right click menu.
3. In the "Open With" window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the "Other Programs" to unhide it.
4. Scroll down to the bottom of the Proof.XML to locate the following lines:
</Feature> <Feature Id="SetupXmlFiles" Cost="1248′>
<OptionRef Id="AlwaysInstalled"/>
</Feature>
5. Change the AlwaysInsalled to neverInstalled so that the line looks like following:
<OptionRef Id="neverInstalled"/>
6. Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
7. You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation.
As usual, as it’s a hack, and before you purchase a valid product key for it, you won’t be able to AND can’t access any updates or Microsoft Office Online.
Jun 15, 2010 | Acer Aspire 5500 5570-2609 Laptop
How to find 8 characters refferal key
  • Click the Windows Start button to open the directory.
  • Click the All Programs button to open the list of programs.
  • Click the Microsoft Office folder to open the list of programs.
  • Click a Microsoft Office program (such as Word or Excel) to launch the Activation Wizard.
  • In the wizard, enter your 25-character activation key. NOTE   If a box appears on this screen to type your 8-character referral key, you may leave the box empty. The referral key is not required to activate.
  • Click the Install Now button.
  • Re-open any Microsoft Office program.
  • Click Internet Activate on the pop-up screen to complete activation.
  • Hope this Helps, Please Rate My Response! Thanks!
    PREM
    Feb 19, 2009 | Microsoft Office Professional 2007 Full...
    Adobe Acrobat 8 Serial number!!
    Hi
    I found a keygen for you :
    http://rapidshare.com/files/53395198/Acrobat_8_keygen___Activation.exe
    how to use:
    Download the keygen from the link then open it and open adobe acrobat 8 then press generate serial number and copy it to adobe acrobat ,it will say it's not valid or somthing like that so you press activate by phone , it gives you an activation number so copy it and paste it in the response box in the keygen and then press generate activation key ,open adobe acrobat again and copy the key to it , it should work i think
    best wishes :]
    Jan 19, 2009 | Adobe Acrobat 7.0 Professional
    MS OFFICE 2007 KEYS
    PREM
    Aug 10, 2008 | Microsoft Office Professional 2007 Full...
    Pinnacle Studio 14 HD Logo
    19 people viewed this question
    Top Pinnacle Computers & Internet Experts
    AL Schehr
    AL Schehr
    Level 1 Expert
    Alun Cox
     Ian Kayhan
    Ian Kayhan
    Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
