Toshiba ct8003 Where is the source button on the CT-8003 to get to the wii menu?
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
Tip
Wii Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu.
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
How to connect wii?
On the TV or Remote there is a button called AV/input/source, press this and select the input the wii is connected to.
Sep 06, 2014 | Toshiba 27A34 27" TV
Toshiba lcd CT-90302
This is not the fault with remote control. It must be the fault with the TV. Check its main power regulator board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Toshiba Ct-90302 Remote Control
How to switch tv over to play games on wii
press menu button and look for source or input and manually do it onscreen, different buttons scroll through choices, enter button selects choices
Aug 20, 2012 | Toshiba 30HF66 30" TV
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
TRYING TO HOOK MY WII UP.,CANNOT FIND A CHANNEL
Try to view the sources on your TV. This is usually found on the menu button of your remote. Browse the sources and look for either the video source.
May 12, 2011 | Sansui 19 in. LCD TV
Can't concetting to the internet.
According to ehow, you should do this:
Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
  • Press the "A" button on your Wii controller to continue from the warning screen.
  • Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
  • Click the "Wii Settings" box on the right.
  • Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
  • Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
  • Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
  • May 08, 2011 | Nintendo Wii Console
    Televison & Video Logo
    Top Televison & Video Experts
