Ruud ueab1415j heat will not stop running
    Top Expert:
  • Heating & Co... Master
  • 12,962 Answers
On Rudd heat pumps the heat position is not the default position for the reversing valve. It either has to be powered to be in the heat position or have gotten stuck in that position. If there is a voltage going to that unit when you are not calling for heat then the mechanism sending it the relay voltage is at fault. A messed up thermostat could be the culprit if it sends out the heat signal to the revering valve when it is not supposed to.
Posted on Nov 24, 2013
Ruud classic 90 furnace (LP) doesn't come on. Fan will run when thermostat set to on (heat & cool both off. Troubleshooting chart?
will you need to put either heat mode on or cool mode to on for any type of operation other than just fan on
Jan 14, 2017 | Ruud Heating & Cooling
Ruud heat pump is not heating.
You may have a problem with the reversing valve. How cold is your location? Do you also have electric back-up heat available in case of extreme temperatures?
Jan 29, 2014 | Ruud 2 Ton Split System Heat Pump
Ruud heat pump, acheiver, 14 years old. The heat seems to be on but the unit outside is frozen over and fan out there is not turning. The motor runs all the time. Is this okay?
In the heat mode the outside unit should have the fan running. In the defrost mode, the fan should not be running but in both cases, the compressor runs.
Jan 02, 2010 | Ruud UBHC Air Conditioner
RUUD M/N UAND-024JAZ;heat operation issue
Its a wiring problem.
w = white
r = red
y = yellow
g = green
c = brown or blue
check how the furnace is wired, it should match the new thermostat you installed.
www.fastacservice.com
Oct 18, 2009 | Ruud Heating & Cooling
Ruud achiever heat pump
the reversing valve needs power to switch to heat. more then likly the o wire is connected when it shouldnt be
Jun 15, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
