Question about Singer 2732 Mechanical Sewing Machine
How do you fix the tension. I would like to see an instruction manual or diagram.
How do you fix tension? I would like to see an instruction manual or diagram. I don't want to buy a manual for this problem.
Parts Diagram For Needle Shaft.
send ur exact model and brand name ..will get ur schematic diagram soon
Sep 20, 2008 | New Home L-373 Mechanical Sewing Machine
Fixing the tension singer sewing machine 522
Yahoo Web Search bernadette I hope this helps you. Did what I could! 8 minutes long. you'll find something. Thank you and leave feedback
Jul 13, 2016 | Singer Sewing Machines
Need diagram for threading and tension
search for instruction manual on Google
Jan 19, 2016 | Sewing Machines
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 | Singer 1507
I have a jones vx810 and have taken the tension dial apart and now icant put it back together as idont know what goes where
you can purchase a new tension dial here
http://www.sewingpartsonline.com/tension-brother-vx-800-sewing-machine.aspx for your machine. This may be simpliest solution.
there is also a manual on that site http://www.sewingpartsonline.com/instruction-book-brother-vx810-sewing-machine-instruction-manual.aspx but I can't see images to know if it includes an exploded diagram of the tension dial.
Jun 27, 2011 | Sewing Machines
Please how can i get instruction manuals for my Newhome sewing machine, bcos am having problem with thread and is locking at the bottom.
you could try www.about.sewing.com for threading diagram and general info on sewing machines.
or for your manual try www.sewingonline.co.uk, www.sewingmanualsonline.com or www.sewingstyle.com, www.manualsonline.com or on ebay.com there are some vendors who sell pdf's of manuals.
I think New Home was bought out by Janome so you might find under one or the other brand name.
Thread issues on the bottom are usually caused by the top tension being wrong so check that the thread is actually between the tension discs and under tension.
Good luck with your machine.
Apr 04, 2011 | Sewing Machines
I need a manual for a Necchi Royal Series, #4795FA. Threading Diagram and Instructions to set the correct tensions on the Thread and foot
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Mar 14, 2010 | Necchi 4595 Mechanical Sewing Machine
How to adjust tension on Toyota RS 2000 sewing machine (CB series
Hi
I found a free manual and parts for my Toyota 9090 on this site. http://www.aisin.fr/index3.php?language=en
The only problem is that the manual is in French but some are also available in English. I found it useful for the diagrams etc.
Try the online guides as well as they give help on adjusting tension, replacing bobbins and needles etc.
Nov 15, 2009 | Sewing Machines
Singer 2732 Mechanical Sewing Machine Logo
53 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
