Question about Samsung WF328AAW Front Load Washer
How to replace the silvercare electrodes in the washer
When the washer mark nd,what that mean?
SAMSUNG Silvercare Front Load Washer will not drain ...
? 3:06
www.youtube.com/watch?v=JozFGnPsQvA
May 4, 2013 - Uploaded by eallevato Troubleshooting a Samsung front load washer that is displaying ...Ordered a new pump and still no spin and "nd" code comes on after a while.
Sep 27, 2015 | Washing Machines
Why does my Samsung washer say HE when done drying instead of End of 0?
When something electrical goes haywire, I advise to always unplug the machine for 5 min and then replug. The electrical "resets" when the power is disconnected. See if a manual for the machine exists...
www.manualslib.com/s/samsung+silvercare+washer.html
Feb 17, 2015 | Samsung Dryers
Have samsung silvercare front loading washer....received and error code of ND what do I do?
"ND" means "Not Draining". I have the same washer, and when I get this problem, it's usually because I've tried to wash something that is causing over-sudsing (like a bath robe that was previously washed in an inefficient washing machine which left a lot of soap behind).
I find that turning the machine off, then selecting "Rinse and Spin" works. I suppose if it's a serious Not Draining problem, it could be that the drain hose is clogged somehow -- start by making sure they're not kinked.
Jul 20, 2009 | Samsung WF337AA Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Samsung Front Loader Washer Out of Control
make sure you take out the 4 srews in the back of the washer .
This is only to hold the drum in place when it is transported to you
Remove them and you should not have a problem.
This info is only for front loaded wahers and not dryers or top loaded washers
Mike T.
teolismike@sympatico.ca
Samsung Silvercare hums, but does not run
FIXED!!!! amen. Attached to the back of the washer was a plastic bag with a tech spec pamphlet. Inside the pamphlet were instructions for running tests via the front control panel on the various cycles to weed out the problem -- fill, spin, drain, etc. The test failed on the draining section citing a problem with the drain pump. So long story short and MANY towels later, I found a small finishing nail in the motor. I had removed the hoses thinking there might be a blockage, but found nothing. So I removed the motor and washed it out. Nothing odd there. So I took the front off the motor and found the nail. It somehow made it through the drain holes in the washer drum but got stuck in the motor.  Thank you Samsung for taping the tech manual to the back of the washer. I could not find it anywhere on the web for this model. After discovering the testing available via the contol panel and the simplicity of the machine, I love Samsung.
Apr 01, 2008 | Washing Machines
Samsung WF328AAW Front Load Washer Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
