Question about RCA Accessory Handset for 25255RE1 25055RE1 25055RE1
Incoming calls ring once then disconnect - RCA Accessory Handset for 25255RE1 25055RE1 25055RE1
I have a mobiwire cell phone and need to know how to change the ring tone please?
Find "Customize"
Press the Navigation key.
Select Profiles.
Highlight General.
Press the Left selection key.
Select Customize.
Select ring tone
Highlight the field below "Incoming call".
Highlight the required ring tones to hear them.
Once you've found a ring tone you like, press the Navigation key.
Return to the home screen
Press Disconnect to return to the home screen.
Sep 26, 2017 | Cell Phones
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
We cannot receive incoming calls.The phone rings once and then drops the call. We can still make outgoing calls.
try leaving only one good working phone in the house, disconnect all others.
You may have a bad phone or too many phones.
Dec 04, 2009 | Lands Phones
The machine does not ring for incoming calls. It MAY ring once. It rings if I adjust the volume, but not for incoming calls. Any Ideas Panasonic KX F2780
there is something wrong with your line,try put on speaker fone. If the there is no line, line is plugged out or your line board is faulty.
Oct 05, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
RCA Accessory Handset for 25255RE1  25055RE1 25055RE1 Logo
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
