Bush hw60 1460d
Conditioner drawer water
3 Suggested Answers
  • 41 Answers
SOURCE: Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
Posted on Jun 12, 2010
paulcharmbur
  • 744 Answers
SOURCE: Water in Fabric Conditioner Drawer
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
Hi. the drawer into which the fabric conditioner is poured, is not being flushed, i.e conditioner remains in drawer. Any idea how I unblock the water inlet ? Thanks
usually the drawer has a plastic tube with cap in it.remove the small cap and clean/wash with water until the residues of the previous conditioner is cleared. then put back the small plastic cap. hopefully it will drain properly on your next use of conditioner
Sep 03, 2015 | Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Why isn't water coming into washing machine
Check water supply to machine, then solenoid valve coil at inlet valve. Sometimes the drawer is so clogged up the water doesn't come through the tibe. Remove the drawer and clean thoroughly
Apr 30, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
Water won't dispense I to the conditioner drawer of my washing machine
Take out the dispenser draw & clean above where the conditioner section is . There is a few very small holes where the water comes out & are easily blocked you might need to use a pin or something similar .
Jan 02, 2013 | Beko WME7247W Washing Machine
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a bush wm-1260b washing machine and the pull out drawer has the three slots for which the midddle slot you put your fabric softener in. After every wash that middle slot fills with water. We can not...
I had the same problem and just searched online and found your question. I have just taken the drawer out by pulling it out as far as it normally goes, then by pressing down on the blue top of the middle (conditioner) drawer the drawer will then pull out all of the way. Rinse the drawer under the tap and scrub off all gunk especially from the middle drawer and in and around the blue component. Reassemble and then push drawer back into the machine, remembering to press down on the blue part in order to push the drawer all the way back into place. I suggest watering down the conditioner a little when putting it in as I think that some are too thick and will leave residue, causing the build up of dried conditioner and the the filling up of water. This seems to have solved the problem and I think the manual does say to clean regularly, which I think I will start doing!
Jan 30, 2011 | Washing Machines
The conditioner drawer is not working
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
FABRIC CONDITIONER STILL LEFT IN DRAWER
water pressure or This video will show you how to keep your soap draw clear and how to service the parts
Aug 24, 2007 | Zanussi FS1155W Front Load Washer
Mar 30, 2007 | Hotpoint WMA50 Front Load Washer
Conditioner tray won't empty
i assume the detergent drawer is really clean especially the conditioner part.fault may be that the roof of the detergent box (the part the drawer goes into) is clogged. open drawer half-way at point conditioner should be taken and check if there is a spurt of water into the conditioner section. if not push a hairgrip or similiar into the holes in roof of box as you may have a blockage there.
Mar 28, 2007 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
