Question about Vacuums
I have a Hoover 12 amp Hepa vacuum. My problem is
I have a Hoover 12 amp Hepa vacuum. My problem is a broken plastic piece of the vacuum that releases the metal tub from the base of the vacuum so I can use the telescope feature that reaches high places. How do I get that replaced?
    Sergeant:
    Champion:
  • 223 Answers
Have you tried www.hooverspares.co.uk I did not look for your particular part but they seem to stock things like latches and so on. Hope this helps
Posted on Nov 27, 2013
SOURCE: Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
Posted on May 28, 2008
reddevil6
  • 1673 Answers
SOURCE: VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
Posted on Mar 06, 2008
GoVacuum1
  • 6 Answers
SOURCE: Bosch Vacuum Cleaner: I changed
Greetings from GoVacuum.com,
It sounds like you may have a bad thermal switch inside the machine. Most vacuum cleaners have a switch connected to the motor, so if the vacuum cleaner is running hot, it will shut off to prevent any damage to your motor. You did all the right things by checking the bag, making sure the hose was NOT clogged, and replacing HEPA filter.
Most of the time on canister vacuums, the reason is caused by a clog in the hose, or somewhere in the powerhead. If you're sure that there is no clog anywhere, it is going to be the thermal switch on the motor.
Here's a link to the parts schematic for the Bosch upright vacuum. I hope it helps you in determining how to access the thermal switch. A word of warning to you before you try it, this is a very tough vacuum cleaner to work on, you may want to bring it in to a vacuum repair shop, as this is not an easy repair.
Here's the link;
http://www.essco.net/Customer/SchematicFrame.asp?FileName=Turbo%20jet%20upright.pdf
Please let me know if you have any other questions,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Posted on Aug 18, 2008
SOURCE: Hoover Self Propelled wind tunnel vacuum U6433-900
I need to replace the actuator pivot arm on my Hoover Wind Tunnel to fix the self propel feature. I can see where it needs to go but I can not seem to get the cover off the vacuum so I can get to it. How do I do this?
Posted on Sep 16, 2008
debbily
  • 101 Answers
SOURCE: WindTunnel HEPA Filter won't spin
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Posted on Oct 12, 2008
How do i fix my hoover windtunnel if self propel is stuck on ?
There is a cable that goes from the handle to the base, the cable or the plastic piece it attaches to at the base of the vacuum may me broken.
Jan 31, 2015 | Hoover Vacuums
The cord rewind pedal and metal piece came off and I can't get it back on. It doesn't appear broken.
It's plastic with chrome paint, not metal. Take it to a vac repair shop and have them fix it. You may break the tabs if you force it.
Oct 14, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
Seeking Manual and Help for Hoover U5075-930 vacuum
The manual will be hard to find but I own several of these Elite syle Hoovers. The plastic top cover that houses the headlight lens, attachment door, etc pops off by gently releasing the plastic tabs that hold it on. They are located on the underside of the machine. Be gentle as those plastic tabs can be easily broken.
Aug 27, 2013 | Hoover U5227-930 Elite Upright Vacuum
How do i replace the hepa filter on a dyson dc18? I removed it and now I cannot put it back on.
It is very simple to change the filter and re-attach the canister. Once you have removed the main canister (the one that has the washable filter) you should see the plastic canister, which houses the Hepa Filter. 1) To make life easy, turn your vacuum around, so you are now looking at the back (where the hose and wand are). 2) Remove the hose and wand as you normally would, if you were going to use them. Just lay it on the floor. 3) Now that they are out of the way, you should see the grey plastic holder, towards the bottom (approx 6 inches above the red release peddle for the vacuum. It is attached to the vacuum with only 2 Phillips-Head screws, and was used to keep the hose in place. 4) Use a screwdriver to remove the screws (one one each side). Once it's removed you should easily beagle to change the Hepa Filter. NOTE: Pay attention to where the 4 inverted latches on the canister are, and pay special attention to the fact that there is an extra latch on the canister, which faces the opposite direction of the others. It is this latch on the canister, which must be located through the back handle of the vacuum, since this was the main latch that was secured by the grey hose piece, which you first removed. 5) To reassemble the canister, line up the clips,especially the one that I just mentioned, and make sure the canister is flush against the base. 6) Now, reattach the hose securing piece that you originally removed, and the Hepa Filter and plastic canister should now be fully secured. 7) Place the hose and wand back into their original position and you should now be ready to vacuum. I hope this was helpful. S.I. Educator
May 29, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Sep 02, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
