Question about True GDM-26 Refrigerator
Compressor wiring diagram for GDM-26 - True GDM-26 Refrigerator
5 Suggested Answers
  • 7 Answers
SOURCE: We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Posted on Aug 13, 2009
SOURCE: Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Posted on Aug 21, 2009
  • 66 Answers
SOURCE: TRUE GDM 26 merchandiser has sealed lines to the
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Posted on Apr 18, 2010
  • 135 Answers
SOURCE: i need a wiring schematic
www.truemfg.com
Posted on Jan 09, 2011
Gdm-26 does not get cold, makes a clicking noise about every thirty seconds from underneath
Replace the thermal/starter relay. It is located on the side of the compressor. It clicks like if you unplugged the unit and plugged it back in quickly causing an over load on the compressor due to the high side still having high pressure and have to wait for a couple of minutes before you plug it in. The relay is at fault. Hope This Helps.
Oct 02, 2013 | True GDM-26 Refrigerator
Wiring diagram for a True GDM-26
hope this helps http://www.mbm-service.de/mbmTechTwo/True_/GDM-5+/Service_Manual.pdf
Sep 26, 2013 | Computers & Internet
Wiring diagram
Should be under the wiring cover behind the vent slats.
Sep 26, 2013 | True GDM-26 Refrigerator
My gdm 26 is too cold. have the control on 1 and it is 33 degrees. I have replaced the temp control and it has a new compressor
Make sure the knob is on correctly, very easy to install wrong. Sounds silly but I find them wrong a lot. Look at the shaft, next that is a tab, the tab goes in the shortest channel under the knob. If it is in the longer channel it slips and is not accurate.
Nov 29, 2012 | True GDM-26 Refrigerator
I have a model GDM-26. It's was blowing really cold, 30 degrees, then warm, 50 degrees, alternating between the two. Now it's not blowing cold at all and the coils on top do not get cool/cold. Both...
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Jun 29, 2011 | True GDM-26 Refrigerator
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
TRUE GDM 26 merchandiser has sealed lines to the freeon and cant access. The fan blows warm air and all the lights work. It just doesnt cool.The compressor was cleaned only 2Xs in 3 years.
Apr 17, 2010 | True GDM-26 Refrigerator
Aug 21, 2009 | True GDM-26 Refrigerator
True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
True GDM-26 Refrigerator Logo
76 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
