Question about Arcsoft MediaConverter
Media converter 8 activation code - Arcsoft MediaConverter
I imported pictures and it doesn't show on my sansa it says unsupported media format
The Sansa Media Converter (SMC) software is required to convert and transfer videos and photos (pictures) to your Sansa player as well as the memory card in your Sansa player.
NOTE: Only the Sansa e200v2, Fuze, and View allow viewing of video files from the memory card.
STEP 1 - Download and install Sansa Media Converter
The Sansa Media Converter application is available via the Sansa Firmware Updater.
STEP 2 - Convert and transfer your video or image files
NOTE: To see a list of supported image/video file formats, see Sansa Media Converter does not convert a file
1. Run the Sansa Media Converter.
2. Connect the Sansa player to the PC.
3. If a Portable Device windows appears, select Sansa Media Converter using Sansa Media Converter.
alt="Image">
4. The Sansa player should appear on the left pane of the Sansa Media Converter console.
alt="Image">
5. Click Add Media to add video or photo files to be converted and transferred.
alt="Image">
(In the sample below we imported an image and a video file)
alt="Image">
6. The converted files are stored in My Album by default. To place them in a different folder, select My Album then type in a new name.
alt="Image">
7. Depending on what Sansa player that's plugged in or if a microSD is present in the Sansa player, click on the Sansa player or the microSD card on the left pane to select where to transfer the converted files. (in the sample below, we selected the microSD card)
alt="Image">
8. Click Convert to covert the files.
alt="Image">
9. Once the files are converted it's automatically transferred to the device or microSD.
10. Click OK when finished.
Mar 13, 2015 | Sansa Audio Players & Recorders
P0740 honda odyssey
P0740 Honda - Transmission Lock-Up Control System Fault Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness is open or shorted
- Torque converter clutch solenoid valve circuit poor electrical connection
Tech notes
On some Honda vehicles the P0740 code may be set by an overheating torque converter problem which is caused by an insufficient flow to the torque converter release circuit.
P0740 Honda Description
The torque converter clutch solenoid valve is activated, with the gear in D4, by the Transmission Control Module (TCM) in response to signals sent from the vehicle speed and the Engine Control Module (ECM). Lock-up piston operation will then be controlled. When the torque converter clutch solenoid valve is activated, the torque converter lockup clutch will engage creating a 1 to 1 RPM ratio between the transmission input shaft and the rotational speed of the torque converter.
Lock-up operation, however, is prohibited when A/T fluid temperature is too low.
When the accelerator pedal is depressed (less than 2/8) in lock-up condition, the engine speed should not change abruptly. If there is a big jump in engine speed, there is no lock-up.
Dec 04, 2013 | 2000 Honda Accord
How do I change a recording to an MP3 file
Generally, the recording format is .amr. If you wanna convert it to mp3 you need a converter to do it. There are lots of audio converters on Internet. You can Google it. I'm a mac user, so I'm using iFunia Audio Converter. BTW, one of my colleagues is win 8 user, he likes Aneesoft media converter.
Apr 07, 2013 | Zarboo Software SpeakEasy Voice Recorder
Need authorization code for adobe photoshop CS 8
serial number : 1111-1111-1111-1111-1111-1111
activation number :3333 -7502- 7650- 3684- 9097-1877 -1523
activation type : normal 24:24
plz provide me activation code foe adobe photoshope sc 8
Apr 25, 2012 | Adobe Photoshop Cs 8.0 for PC
1998 jeep grand cherokee 4x4. have the p0740 code. have to start from neutral, then shifts faily well. May start fluttering and making noise, have to put back to N, then to D and once again will shift. ...
P0740 JEEP - Torque Converter Clutch Circuit
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission shift shock
- Vehicle may not shift into the highest gear
Possible causes
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
When is the code detected?
Torque Converter Clutch (TCC) unlocked for 10 sec., ECM commands converter lock-up and did not record engine speed drop.
P0740 JEEP Description
Mar 27, 2011 | 1998 Jeep Cherokee 4WD
Micro 8 gb jpeg says unsupported media
You need to use the supplied Sansa Media Converter program to convert and transfer photos and videos. If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Problems with activation of adobe acrobat 8 professional
Follow these steps to install "Adobe Acrobat 8 Professional" :
1. Double-click on the setup file.
2. Folow the instructions, and the installation will continue.
3. When asked to activate the product, choose "More Activation Options" and "Activate Over Phone".
4. You will now be given an "Activation Number / Authorisation Code".
5. Use this code and serial to activate your product!
* Internet or Phone connection is required for "Adobe Acrobat 8 Professional" product activation !
please rate this advice if it helps...tc! :)
Jan 15, 2010 | Adobe Acrobat® 8.0 Standard Full Version...
How do I save AVCHD movies as MPEG files? My software converts them to .cont or .iis or .m2ts or .tmb I have a panasonic dmc-ft1
Wondershare Video Converter Platinum is the best HD video converter and AVCHD video converter which can convert HD video and AVCHD video to avi, convert m2ts to avi, convert mts to avi, convert ts to mpeg etc.. with excellent quality.
Sep 22, 2009 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
I have the philips mp3 GoGear with 8 GB, how do i
try using the arcsoft media converter 3 it automaticly transfers the files over to the right folder in the player see if that helps
Jul 19, 2009 | Philips GoGear Flash MP3 Player
How to convert .ram files to mp3
serial number:1045 - 1082 - 3193 - 5693 - 1535 - 2033
Activation number:4841 - 2934 - 7262 - 7072 - 9253 - 2896 - 2183
Activation type:Normal 93: -8
i need authorization code for cs2(photoshop)its very urgent
gve me reply fast
Jan 20, 2009 | Microsoft Windows Media Player
Computers & Internet Logo
15 people viewed this question
Top Arcsoft Computers & Internet Experts
Piyal Perera
Piyal Perera
huzaifa mahmood
Are you an Arcsoft Computer and Internet Expert? Answer questions, earn points and help others
