Question about Zap Stick stun Gun With Flashlight
I touched my stun gun to foam & now it wont work
I think the foam melted to it so maybe if I clean it it will work?
Stopped working normally, makes low grumbling noise
have a look at the glass plate rollers first if there sticky free them off, but if the noise is from the inside of the microwave its likley to be a short in the mains coil witch case dont even think of fixing it
it would be far cheeper to buy a new microwave insted
a word of warning,,, dont think you can fine an easy fix for it, if its an internal fult, and dont go tinkering inside of it, there is very high voltage inside this microwave it can kill you if you tuch the wrong part have ever seen a police stun gun working???????
it realy hurts you,,,
your microwave has the stun guns very big brother inside of it,, it dont stun,, it kills!!!!
best to plat it safe dump it and buy a new one
there only about £50 today
so is your life worth more than £50???????/
Oct 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The audible beeper is failing. We can hardly hear it. Everything else in unit is working fine. Thanx! Ed Bruder edbruder@wowway.com
it could be fixed but at what cost?
ask your self how old is the microwave?
would a new one cost less to buy, there very cheep now, is it worth the repair price,,, however please dont think of having a go at it yourself
there are 1000's of volts inside of this microwave stored in the capacitor even if its been switch off for a long time, this capacitor can kill you if you go tuching it, is it realy worth taking that risk?
have you ever seen a stun gun working??? it realy hurts you!
but this microwave has the stun gun's very big brother inside of it,,
it dont stun you,,, it kills you,,,
and all that to save a fuw bucks?
Oct 25, 2009 | Emerson MW8675W Microwave Oven
Maytag microwave Model MMV5100AA turntable no longer turns. Is this an easy fix? The rest of the Microwave works fine. I think I may have flooded the floor of the microwave with water. It worked awhile...
to be realy honest ,,, yes! but be warned there is a very big capacitor inside this microwave and it will be charged up with 1000's of volts,
if you tuch it, your dead! be warned dont tuch it!!!!!!!!!!!!!!
have you ever seen a stun gun working??? they realy hurt you!!!!
well this microwave has the stun gun's very big brother inside of it and it wont stun you,,,it will kill you!
if i were you i would drop it into the repair man to get him to fix it for you,,, or get a new microwave,, there very cheep now,, is it realy worth killing your self for a fuw bucks?
Oct 25, 2009 | Maytag Microwave Ovens
Carnt get goodmans me21w microwave out of defrost mode
this is most likley to be the programer packed up,if it wont let you out of defrost its not worth getting it repaired as it will cost to much
ask yourself how old is it? rember there so cheep today! from £50 up!
please dont think of trying to have a go yourself at fixing it,
inside this microwave there is very high voltage,, in the order of 1000's of volts,,,it could kill you if you tuch it! be warned,
have you ever seen a stun gun working?? it realy hurts you!
this microwave has the stun guns very big brother inside of it,,,,,
it dont stun you,,,,it kills you? is it realy worth it for a fuw bucks!,
Oct 25, 2009 | Microwave Ovens
Not all the buttons work on the panel of the mircowave
buttons that stop working could be many things more often its the pad its self but it could also be the programer,,,what ever it is, its not realy worth having it repaired a new microwave costs from £50 up at todays prices,, ask yourself this,,,, how old is it?????
also please dont try fixing it yourself, there is some very high voltage inside your microwave even if its been turned off for a long time,,,
this voltage can kill you,,, be warned!
have you ever seen a stun gun working,,,it realy hurts you!!!
it wont just stun you,,, it would kill you,,,
is it realy worth it just to save a fuw bucks??? play safe buy new,,
Oct 25, 2009 | GE Microwave Ovens
Our r-1491 microwave fan won't shut off, even when
its just the door switches playing up on you,,but is it worth getting it fixed? after all a new microwave onle costs from £50 up today,,
please dont try fixing it yourself unless you realy know what you are doing in there, there is 1000's of volts hiding in there even if its been switched off for days, and them volts will kill you,
have you ever seen a stun gun working???it realy hurts you,,,,,this microwave has the stun guns big brother inside of it,,and it wont stun you,,it will kill you,, is it realy worth that for a fuw bucks?
Oct 24, 2009 | Sharp R-1491 Microwave Oven
Ge profile microwave wont heat replaced fuse but still not heatin
most times if you have tryed a new fuse and its still not working, its a dead microwave by dead i mean bump it, the cost of having a repair man look at it would likley cost more than getting a new one at todays prices a new microwave costs less that £50 ?????????
ask yourself this,,, how old is it? is it realy worth spending hard erned cash on an old lame duck???? treet yourself go buy a new one,,,
please be warned,,, dont think of having a go at fixing it yourself,,,inside that microwave is well over 1000 volts tuch it and it kills you,,,
have you ever seen a stun gun work??? it realy hurts you,,,
inside your microwave is the very big brother of the stun gun,,,
it wont stun you,,, it will kill you,,,
and for £50 is it realy worth it
Oct 24, 2009 | GE Microwave Ovens
MY MICROWAVE WONT START BUTTONS WORK BUT WONT
the problem with microwaves is there like light bulds,,, fine for years then the just pop off, whatever it is there is very little you yourself can do with it bar check the plug fuse,, if thats ok dont even think of opening it up to have a look inside, you are very likley to just kill yourself
inside that microwave is a big capacitor that holds 1000, of volts and they can and do kill if you tuch the wrong bits of them,
have you ever seen a stun gun work? well that capacitor is its very big brother, only it wont just stun, it will kill you out right...is it worth the risk??? no! so drop it in the shop for repair or better still bump it and get a new one,, and up grade it as well,
Oct 24, 2009 | Whirlpool MH7135XE Microwave Oven
GE XL1800 model #JVM1850CD 001 -turntable won't turn and makes a grinding noise when turned on. Any suggestions on part number to replace the motor?
why are you diceing with death ???
to fix your microwave will cost you more that £50 thats over the price of a cheep new one??? darft that is,, why not just buy a cheepy and use that? also i do hope you know that inside your microwave there is very high voltage over 1000 volts,,, it could easly kill you if you tuch the wrong part,,,
have you ever seen a stun gun working? it realy hurts you!
your microwave has the stun guns very big brother inside of it,,,
it wont stun you,, it will kill you,, so far you have been lucky your still here, please stay that way play it safe go out and buy a new one?
Oct 24, 2009 | Samsung MW1030WA Microwave Oven
Zap Stick stun Gun With Flashlight Logo
648 people viewed this question
Top Zap Stick Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Zap Stick Retail Supply Expert? Answer questions, earn points and help others
