Question about Konica Minolta Computers & Internet
HOW TO SHUT DOWN fiery model # X3eTY2-10 - Konica Minolta Computers & Internet
I have the software, Fiery for 65 C-KM version 1.1, how do i install it
Installing Fiery software is notoriously tricky! Although they refer to a different Fiery model, the files in the following link will give you a good idea of what is involved :
MediaFire
..... particularly the software installation guide.
Hope you get it sorted.
Mar 24, 2014 | Konica Minolta bizhub Office Equipment &...
My EFI, Model: Fiery X3eT-05 is showing FF, what should i do?
power off then on. If this does not work you may need to either reload the fiery, or need a patch for the software to fix this.
FIERY X12 & DC12 NOT CONNECT
In my experience, power both machines down using the preferred method (the copier will either have a sticker on it telling you how to safely shut down, or it may say to just flip the switch, and the fiery server should have a menu screen on the front of it, navigate to the restart option) then power up the Feiry server first, then power up the copier. If you use command workstation, there may be a reboot option as well. Also make sure all network cables are properly seated before rebooting machines. The most common issue is that when the machines are on for a long period of time, the just loose connection, and the reboot re-establishes a connection.
Mar 15, 2011 | Xerox DocuColor 12 Printer
Konica Minolta bizhub 6500 pro/Fiery controller scanning problem
Hello a Fiery print controller is basically a computer, which needs to be rebooted once a week to get rid of temp. files. Try shutting down each fiery every Friday and restarting Monday morning and your problems will be resolved. What model Fiery's do you have (IC-408, IC-901),? let me know which model and I can see if their is a patch to correct this issue. dave.herron@att.net PS: I am full line KonicaMinolta dealer
Nov 24, 2009 | Konica Minolta Office Equipment & Supplies
Canon clc 5100 problem
try a clear server on the Fiery. shut down/re-start
**Warning if u need your job log saved do so before clearing Fiery server.
Mar 09, 2009 | Canon CLC 5100 Copier
Fiery patches
hi better u try to xerox.com/drivers..
Oct 01, 2008 | Xerox DocuColor 12 Printer
Fiery "Hangs" while shutting down
What I would suggest is call 1-800-821-2797, have your machine serial number available and ask for " Second Level Support".
I seem to remember there is a fix for that, but I no longer have a laptop with that information on it.
Second Level Support should be able to resolve that for you pretty quickly.
Jul 10, 2008 | Xerox DocuColor 12 Printer
Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Jan 10, 2008 | Xerox DocuColor 12 Printer
Computers & Internet Logo
217 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Tom Chichester
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
