Question about Sunbeam Vacuums
YLR2-5-67H3 sunbeam water cooler, the cold water does not get cold
Sunbeam steam mop is not heating the water
Call Sunbeam Customer Support .... 1-866-726-1150
Regards,
Dennis
Aug 30, 2014 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
Prima water cooler just noticed that the cold water is not cold. Looked in back and copper coils all iced up.. turned off and put cut to collect water, what needs to be replaced> have another...
try to adjust to lessen the setting of thermostat maybe the setting is to full thats why the thermostat cannot cut off after the water chilled. then observe the unit.
Mar 02, 2011 | Vacuums
I own a watercooler 4 yrs old model # whkmd30The bottle water get extremely hot. There is good ventilation Any suggestions
Your water cooler has a Hot water section, also-- correct?-- You have 2 faucets, right?-- One COLD and ONE hot!
Is it possible that the section that does the HEATING, is stuck ON and is in some way heating the water back up thru the connection, into the big bottle?
Another possible thought: Is there a heater to prevent freezing of the bottle?-- Maybe it is stuck ON
Note: Your question ended up under Vacuums-- We are just trying to help-- Feel free to re-list your problem up there where water coolers are-- OK?
Sorry we couldn't be more helpful here in the Vacuum cleaner area-- :-)
Mack B
Jan 29, 2011 | Vacuums
Hi I have a new sunbeam Eskimo ice maker I have had it on now for 3 hrs approx the water is cold and i have it on the med size blocks its only bringing down 4 ice blocks in the 3 hr period is that normal...
Sorry to read about your problem, I hope this helps you out.
yes
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Sunbeam Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
Vacuums Logo
Top Sunbeam Vacuums Experts
Terry Weaver
Terry Weaver
Laura Muresan
Laura Muresan
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
