Question about Monte Carlo Fans - Ceiling Fan Light Kit MC21PW
Fan will not turn off
I replaced the batteries in the infra red wall switch. Also it is still running in Reverse after hitting the reverse button.
    Genius:
  • Monte Carlo Master
  • 1,617 Answers
Try changing the frequency in the receiver & transmitter. If that doesn't work then you probably need a new receiver.
Posted on Nov 25, 2013
Why doesn't ceiling fan reverse?
Putting the fan in reverse is done by mechanically reversing the leads powering the motor. All the wall switch does is supply the power and the fan circuits take care of the speeds and direction.
Your problem is with the fan reverse control and/or electronics.
Sep 08, 2015 | Dryers
How to manually reverse ceiling fan direction.
You did not provide a make or model of your fan, but check your owner's manual if you have one. There should be a website or a service support telephone number to obtain more information. Most ceiling fans have a reversing switch on the fan itself. They can be a pull-chain type or a slide switch.
Jul 25, 2015 | Dryers
How do I get the fan to work using the remote ? All buttons (even the fan buttons) only operate the light, and only the upper light at that. Battery was low. Thought that was the issue, replaced with
First of all, that's a low-end fan made for Home Depot only! Did the remote come with the fan or was it an add-on remote. If there are any pull chains on the fan & light, then it was an add-on remote. If there is a reverse switch on the fan, then the reverse on the remote transmitter will not work. Probably need a new receiver.
May 05, 2014 | Dryers
While fan was on ,pet jumped on and pressed Reverse
WHEN THE PET HIT THE REVERSE BUTTON THE MOTOR WAS MOVING IN THE FORWARD DIRECTION AND TRIED TO REVERSE AND STARTED TO WEAKEN THE WINDINGS OF THE MOTOR IT MAY RUN A WHILE LONGER BUT I WOULD REPLACE . FAN MOTORS DON'T LIKE THAT SUDDEN REVERSE
Aug 10, 2009 | Hampton Bay Dryers
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
My ceiling fan has no reverse switch, how do i change the direction
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Jul 18, 2009 | Hampton Bay 24002 Ceiling Fan
My fan reversed, but my controller does not have a reverse button
There is a switch on the housing of the fan. It is under the blades and above the lites if you have lights. Also same area as the chains. That is the reverse switch you might have hit it when cleaning the fan. just flip the switch iy goes left to right or reverse.
Good Luck and please rate
Jan 23, 2009 | Minka -Aire Brushed Nickel Remote Control...
Reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Nov 20, 2008 | Hampton Bay 52 In. White Redington...
Hampton bay altura 68
Read this on another thread - apparently the solution came from HB's tech support.
Turn the fan speed to HI and then select Reverse.  You should hear a "click" and see the fan reverse direction.  It seems that the reversing relay only works when the fan speed is set to HI.
Good Luck!!
Two Metre Man
Jul 12, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
56 people viewed this question
Top Monte Carlo Dryers Experts
ka4iup
ka4iup
Tom Chichester
Are you a Monte Carlo Dryer Expert? Answer questions, earn points and help others
