Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba tv yellow blinking lights 42xv540u - Toshiba REGZA 42 in. Flat-Panel LCD HDTV
5 Suggested Answers
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
I have a 56 inch tohiba DLP (56 HM 195). Replaced the bulb for the second time this year. last time only lasted 3 months. TV is tough to turn on. When I get it to turn on, and then shut it down, the yellow light blinks constantly for 5-7 mintues. Then it shuts down completely. Is the set overheating? There is nothing in the manual that speaks to this issue. thank you
Posted on Aug 15, 2009
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
roety
  • 585 Answers
SOURCE: Toshiba 65" Rear Projection DLP TV
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the Lamp replaced
Use google to buy one using the model #
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 20, 2009
ginko
  • 19396 Answers
SOURCE: toshiba 72HM195 blue light blinks
Hi.
Rather than the number of blinks you need to count the blinking time intervals.
If the yellow is staying on 3 seconds, and the blue blinks last half second, then the problem is the lamp cage door. In that case:
  • Disconnect power cord for ten minutes.
  • If problem persists, disconnect again and check lamp cage door.
  • Replace door switch (must be done by technically trained person).
I uploaded here the full error code troubleshooting for this model. Click on the link, then click on the picture again to enlarge. Alternatively print out the error codes page.
Regards.
Ginko.
Posted on Mar 27, 2011
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
How do i remove swivel base from toshiba regza 42xv540u
Make sure you check the owner's manual. You can probably get a free download if you lost yours.
Some TVs have screws on the backside near the bottom, not just underneath.
Jun 17, 2014 | Toshiba REGZA 42XV540U 42-Inch 1080p 120Hz...
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Yellow light blinking on tv will now come on
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Apr 26, 2010 | Toshiba 65HM167 65" Projection Television
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
TV will not turn on Yellow power ind. Light blinks three times...
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
How do remove the base on a toshiba 42XV540U?
toshiba 42xv54ou it wount trun on and it blink a yellow light three times
Dec 06, 2009 | Toshiba REGZA 42XV540 42 in. HDTV LCD TV
hi
can u tell how much times the light blinks..
then i can give solution...
thank u,,,///please rate it
Jul 02, 2009 | Toshiba 50HM67 50" HDTV
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
